Weird Idle Issues
Old Feb 4, 2009 | 08:17 AM
kcc1kjh's Avatar
Weird Idle Issues
Yesturday during are snow storm I remote started my car so it warm up, and while i was walking to my car my engine was reving like crazy. Anywhere from like 1k to around 2k every second. I do have promblems with my exhaust up front so that can cause the promblems. It stopped as soon i started driving though but its just strange how that happen. Anyone else have a cause for it?
Old Feb 4, 2009 | 11:41 AM
kamdog211's Avatar
Had the same issue with my 03 TL, look up EGR or IAC, those might be your issue.
Old Feb 4, 2009 | 01:09 PM
TLin401's Avatar
'13 Hyundai Sonata
Have you ever tried seafoaming the car? It might or might not solve the problem but it will at least help a little because it helps the idle.
Old Feb 6, 2009 | 07:56 AM
kcc1kjh's Avatar
yea ima do that once i fix my exhaust issues
Old Feb 6, 2009 | 08:02 AM
andrew070489's Avatar
^^ if the exhaust leak is large enough the lack of backpressure will make your engine run funny.. the engine will try to correct the lack of pressure by revving a little, don't worry. just get the exhaust fixed..how cold is it there by th way?
Old Feb 11, 2009 | 10:57 AM
kcc1kjh's Avatar
the day it happen, it was around 20degrees. You could be right though about the lack of air pressure. My car is going in the shop tommorow for the timming belt and water pump installed. I'ma question the mechanic about my exhaust leak so he can tell me where exactly where its comming from and have my brother inlaw fix it for the cheap. lol
Old Feb 12, 2009 | 09:54 PM
justbre's Avatar
I am having a problem with my engine revving on and off. My exhaust has holes in it and I haven't gotten it fixed. Is that my problem also, with the lack of back pressure?
Old Feb 12, 2009 | 10:08 PM
KrayzieDxC's Avatar
Khmer Pride
i had a rough idle before my start shaking hard, so i clean the control valve idle and cleaned it and work great again
Old Feb 12, 2009 | 10:09 PM
desired_speeds's Avatar
bleed your coolant. It may be the problem.
Old Feb 13, 2009 | 12:02 AM
justbre's Avatar
Also, I cannot get my heater to work in my car unless I'm on the highway. What would be the cause of that??? Someone told me that the thermostat could be affecting it.
Old Feb 13, 2009 | 12:16 PM
kcc1kjh's Avatar
just got my baby fixed today. I got the timming belt kit installed and valve cover gasket replaced. they look at my exhaust and i need an whole new muffler assembly but i get that fixed next week. everything came up to about $425 with about 4 hours of labor. And the exhaust gonna run $320 plus an hour of labor
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
DwDrummer
5G TLX Problems & Fixes
Sep 14, 2015 08:20 PM
Mike Bertram
Sep 10, 2015 09:27 AM
NSolace
Sep 3, 2015 08:14 PM
