Mirror housing
Old May 9, 2006 | 07:08 AM
2TLS's Avatar
Question Mirror housing
Anyone know how to replace the passenger side mirror housing?
I cracked my housing and have a new housing to replace it with.
Does the mirror pop out so you can access the screws behind it?
Old May 9, 2006 | 10:27 AM
ITL's Avatar
ITL
I do my own work.
more than likely, the trim piece inside the door (triangle at the front of the window) comes off providing access to a few bolts holding the mirror to the car.
Old May 10, 2006 | 07:16 AM
2TLS's Avatar
I can't just pop the mirror out?
Old May 10, 2006 | 09:15 AM
ITL's Avatar
ITL
I do my own work.
You could, but it probably wouldn't do you much good.
Old May 10, 2006 | 09:20 AM
UnsanePyro's Avatar
Registered Driver
Installation is the reverse of removal
Old May 10, 2006 | 10:24 AM
2TLS's Avatar
This is very helpful.
Thanks.
Old May 10, 2006 | 10:36 AM
ITL's Avatar
ITL
I do my own work.
I stand corrected. Good job, UP. For some reason, I was thinking this was the 3rd gen forum
Old May 10, 2006 | 01:04 PM
UnsanePyro's Avatar
Registered Driver
Haha, yeah, when I went to look for it I was acutally suprised that it came apart like that, I've done it before with other cars and it has been a trim piece inside that you take off.
Old May 10, 2006 | 02:23 PM
ITL's Avatar
ITL
I do my own work.
yeah, it makes sense for removing the housing. I was thinking that he would be replacing the whole assembly, whereas I believe the base would have to be detached from the inside...oh well, you got the scans up there. Can't ask for much more than that.
Old May 11, 2006 | 07:01 AM
2TLS's Avatar
Does the mirror pry off easily? I seem to have a hard time prying the mirror off.
Old May 11, 2006 | 08:05 AM
UnsanePyro's Avatar
Registered Driver
I've got no idea, I just grabbed that out of the service manual, I've never done it before.
Old May 11, 2006 | 08:35 AM
2TLS's Avatar
Maybe is different because my mirror a heated mirror.
Thanks anyways.
Old Jun 1, 2006 | 08:34 AM
klp45's Avatar
Unsane, does the manual have any pictures the spring mechanism or the mirror pivot?
Old Jun 1, 2006 | 10:52 AM
2TLS's Avatar
My mirror is heated and I found that there is a service hole on the bottom of the mirror housing. Just insert a phillips screwdriver to loosen and the mirror comes right out. Since my mirror was cracked I had to take the door panel off and the whole housing to replace.
ITSJESTER
17
Dec 6, 2018 02:29 AM
Jul 16, 2017 07:33 AM
soupi
14
Nov 15, 2015 11:15 AM
