i need help guys
Old Nov 19, 2006 | 11:11 AM
yonkers2.5tl's Avatar
3rd Gear
i need help guys
wassup everyone this is 2.5tlinspire i jus changed my name cuz i 4got my old password...n e way i was wondering where the waterpump on the 2.5 is located...is it the piece that is connected to the hose from the radiator or is located down more..thanks for the inputs
Old Nov 19, 2006 | 05:20 PM
TexasHonda's Avatar
The water pump on the 2.5TL is at lower end of the timing belt cover. You can see part of the pump where the lower radiator hose connects to pump. Pull cooling fans, crankshaft pulley, timing belt covers, timing belt, and finally water pump can be accessed. Don't try this DIY w/o a shop manual of some type.
good luck
Old Nov 19, 2006 | 06:31 PM
3rd Gear
thanks 4 the advice..i figured thats where the antifreeze was leakin from..i guess ima get my pump n timing done...how long can i drive with a bad pump..it leaks only when the car is on but it duznt over heat..
Old Nov 20, 2006 | 06:18 AM
TexasHonda's Avatar
They will usually begin to squeak when the coolant begins to corrode the pump bearings. You don't want to wait too long, but you might get a month of driving before bearings begin to fail. I wouldn't cut it too close.
good luck
Old Nov 20, 2006 | 06:43 PM
2.5tl inspire's Avatar
so obviously i gotta keep adding antifreeze now but should i fill up the radiator now or the reserve tank as usual(by the way i use str8 antifreeze not 50 50 is that ok)
Old Nov 21, 2006 | 06:17 AM
TexasHonda's Avatar
You should use antifreeze at 50/50 mix w/ distilled water. I've read that cooling is not as good, but doubt that anything horrible will happen w/ pure antifreeze.
good luck
Old Nov 21, 2006 | 01:40 PM
bpjadhav's Avatar
1998 2.5TL
I've a leaking waterpump - I bought an aftermarket water pump when I did the timing belt (about 35,000 miles back). The pump developed a leak within 20,000 miles The leak isn't bad and I keep checking the radiator - every once in a while the level of coolant in the radiator goes down, but it isn't replenished with coolant from the reservoir. I add some pre diluted coolant to the radiator and everything is fine again. I'm planning on having the timing belt and water pump done again. I may replace the radiator hoses too (my car is at 140K).
1. Check level of coolant in the radiator and fill it up if the level is low. Don't go by the resevoir.
2. I'd strongly advise buying the waterpump from a dealership i.e. get a genuine Honda waterpump. There's one for sale on ebay for $79, I bought a new one from the same seller:
http://cgi.ebay.com/ebaymotors/1995-...QQcmdZViewItem
Old Nov 22, 2006 | 06:15 AM
TexasHonda's Avatar
The water pump gasket is the sandwiched paper type that can be prone to leakage. It is essential to use gasket remover spray and a razor scraper to remove the old gasket and get a clean surface for the new gasket. I like to put a thin (very thin) layer of red high temp RTV on the gasket to hold in place while mounting the pump. Torque bolts to spec in the specified sequence.
good luck
OculiAquilae
Nov 19, 2018 02:24 PM
funkbro2
Nov 17, 2015 10:23 PM
knight rider
Oct 1, 2015 10:29 AM
ja4lyfe
ZDX
Sep 17, 2015 09:10 AM
Nicho863
Sep 3, 2015 09:16 PM
