Rough Engine
Old Nov 16, 2006 | 11:05 PM
mrlifts's Avatar
Rough Engine
I have a 97 3.2 and when the engine reaches 1,500 rpms, it starts to sound like a diesel engine. However, it runs just fine at all other RPMS. The Dealer says it is normal for all 97 TLS. If I put the car in neutral and rev to 1,500, it starts to run rough. Does anyone else have this problem? If so, what cured it?
Thanks,
Mrlifts
Old Nov 16, 2006 | 11:14 PM
Ken1997TL's Avatar
Its normal. Its a 90 degree V6, which tends to be rougher than a 60 degree. The 3.5 RL's engine has a balancer which smooths this out. Our engines dont obviously.
Old Nov 17, 2006 | 01:53 PM
96teeluxury's Avatar
Tri State ViP Crew
Originally Posted by mrlifts
I have a 97tl diesel engine
imagine.
Old Nov 17, 2006 | 02:35 PM
pi1996's Avatar
my car sounds rough in drive.. when i rev it in park its fine..
its 2.5..
maybe my bypass valve on the intake is stuck..
but, then it would be same in park.
i do have one clip missing where air filter cap is.
would that do it?
anyway.. any ideas anyone?
Old Nov 17, 2006 | 02:50 PM
alphason'sac's Avatar
Acura Vet
its 2.5..
would that do it?
Anyone? I have the same problem with my 2.5. She sounds/feels rough at a stand still while I am in, but when I put her in neutral it's smooth as silk. Other than the fact that she is 10 years old, I wonder what causes that. It hasn't always been that way.
Old Nov 19, 2006 | 05:24 PM
TexasHonda's Avatar
A new set of plugs, wires, distributor rotor, and distributor cap from the one time factory emissions service made my 2.5TL purr like a kitten, under load or not.
I've heard of damaged engine and transmission supports causing vibration. This would be consistent w/ vibration w/ the engine in gear and stopped.
good luck
Old Nov 20, 2006 | 10:27 AM
crucial24's Avatar
am is it normal going off topic a little when my TL 96 2.5L is in park or stop its rpm is lil under 1 is that sound correct to you or is there a power issue?
Old Nov 20, 2006 | 12:03 PM
TexasHonda's Avatar
Mine runs about 750 rpm at idle. If you're at 1000 rpm, you may have a slight air leak in the intake system somewhere. It should definitely be in the range 750-850 rpm when fully warm.
It may help to clean the EACV and throttle plate w/ throttle body cleaner.
good luck
Old Nov 22, 2006 | 10:12 AM
crucial24's Avatar
oh ok thx 4 da info
Old Nov 23, 2006 | 11:43 AM
crucial24's Avatar
good luck
but do you have a sound sytem in your car aftermarket or some sort of electronics that use quite a bit of power??
Old Nov 23, 2006 | 11:53 AM
meazz1's Avatar
Make sure the exhust manifold is not cracked.
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
gator90065
Oct 8, 2015 10:14 AM
Frathora
Sep 28, 2015 11:29 PM
IlliniAcura
Sep 19, 2015 09:31 PM
Caddy
1G RDX (2007-2012)
Sep 18, 2015 12:44 PM
