HELP: Replaced tail lights and "Tail Lamp" light is on.
Yesterday, I installed my JDM UA2/UA3 Red & Clear Honda Inspire Tail lights and as I was driving to work today, I noticed the Red "Tail Lamp" light is on in the cluster. Am I supposed to reset anything? My tail lights are working properly, I have no idea why the cluster light is on. Any help? Thanks.
Did you possibly forget to plug ANY of the rear bulbs back in? I'm sure that would set off the sensor. I'm sure the car doesn't know if you have a different set of tails.
Go90Go, you didn't have to switch the bulbs from your stock tail lights, did you? The JDM Tail lights I have, had all the bulbs already in them. All I did was plug my factory harness into them and all seems to be working fine. I will double check everything though..
There is a little box that comes with the tail lights. There is one on the driver's side of the old tail lights. That box sends the brake light signal to the tail light. Also since you just plugged the harnesses in one of the bulbs may be bad. I would change the hatnesses back to factory because you know those bulbs work.
mada51589
Jan 9, 2025 04:40 PM
rockyboy
Jan 25, 2016 06:00 PM
wusty23jd
Sep 24, 2015 11:41 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
