Crankshaft Pully
Old May 18, 2009 | 08:47 PM
DRSS's Avatar
9th Gear
Unhappy Crankshaft Pully
Can anyone tell me which way the bolt on the crankshaft pulley of a 1998 TL comes off clockwise or counter clock wise?
Old May 18, 2009 | 10:33 PM
desired_speeds's Avatar
counterclockwise, just like how any normal bolt comes off.
Old May 18, 2009 | 11:10 PM
TLin401's Avatar
'13 Hyundai Sonata
Lefty loosey, Righty tighty
Old May 19, 2009 | 02:43 AM
DRSS's Avatar
9th Gear
Thanks guy's
Old May 19, 2009 | 12:09 PM
TexasHonda's Avatar
If you're trying to remove, it can be a challenge. A good air impact will sometimes work. Or a long breaker bar + cheater pipe w/ restraint tool to hold the engine from turning.
good luck
Old May 19, 2009 | 04:27 PM
meazz1's Avatar
I never used an air impact but always wondered how can one fit that in such a tight space? Do you have to remove the radiator?
Old May 19, 2009 | 07:13 PM
TexasHonda's Avatar
I also have an Accord and momentarily forgot what I was respondiing about.
Yes, you would have to remove the radiator to bring an air impact into play. I've always used retraint tool on one breaker bar and deep impact socket on the other breaker bar on the 2.5TL.
regards
Old May 20, 2009 | 02:29 AM
on 3.2s, just put a socket into the bolt and rest a breaker bar pointing to the left side of the engine and give the starter a quick crank (about 1 sec only). it might work on 2.5s too, use your brain on it.
CLsuperhero
Sep 23, 2015 12:53 PM
Sep 17, 2015 09:01 PM
gavriil
Mar 5, 2007 05:55 AM
CleanCL
Nov 28, 2006 08:22 PM
