heated seats
Old 10-02-2008, 10:33 AM
Ibz
Peace
Ibz's Avatar
heated seats
Winter is almost here another problem with my TL the part you sit on does not work, no heat, just the back part. Any thoughts on a fix. Thanks
Old 10-02-2008, 11:41 AM
大日本帝国
Go90go's Avatar
Have you checked the harness underneath? It's possible that something either dislodged it or cut the wire, especially if you put things under the seat.
~Cheers~
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
check the gen 2 thread, fixed seat heat for $3
under the seat cover is what looks like an old electric blanket -the kind with with wires sewn into it.
One of the wire leads in the butt area has gotten broken, often where a mans wallet will exert more pressure in one spot on the seat
Remove seat- remove seat cover- access wire- cut out bad section- splice in new,
replace seat cover
Old 10-02-2008, 07:47 PM
Ibz
Peace
Ibz's Avatar
Thanks im on it
Old 10-02-2008, 07:55 PM
KaMLuNg's Avatar
Received 1,090 Likes on 767 Posts
i am going to have to do this soon before it gets cold... i have the same issue on the passenger side bum area... only the lower back works....
Old 10-03-2008, 08:53 AM
Ibz
Peace
Ibz's Avatar
Tried to look for the info in second gen thread, could not find it maby I just missed it not sure. It doesent sound like too hard a job but that info would be much more helpful to try and deal with this.
Old 10-03-2008, 10:34 AM
andrew070489's Avatar
whats up guys, i got a 97 tl 2.5 premium (no heated seats) just had back seats and armrest re-upholstered, but waited on the front. i was gonna order the real leather replacement covers off ebay and put them on the front.. so my question is would it be possible to make both my front seats heated and give it the stock appearance.. order the heated seat on/off from a 3.2 on ebay and retrofit into my center console? or my storage area under my armrest?
Old 10-03-2008, 11:00 AM
01tl4tl's Avatar
Kam- check the owner book- Im not certain on your year
BUT-
the passenger seat on gen2 has butt heat only- no low back- due to side airbag and sensors in the seatback that would be disturbed by the heat
check the DIY section in gen2 or use search for `Fixed seat heat`
for the full pic thread with great directions
Mainly - disconnect battery!!! mark the 2 connection wires under the seat as a and b- dont want to mess up when reinstall and they will fit each other--stupid~
Old 10-03-2008, 11:03 AM
01tl4tl's Avatar
andrew- you would need the inner fiber/fabric seat covers that go over the foam but under the leather
that contain sthe actual wire heater elements sewn into it- it really is like an old electric blanket!!
those are very $$$$ new
When the dealer wanted $750 to replace the entire heat cover- a ziner went in with a few tools and figured out what the prob and fix is
3 bucks covers a piece of wire- solder- shrink wrap- electrical tape
Old 10-03-2008, 11:04 AM
01tl4tl's Avatar
always consult the local auto dismantling and recyling- formerly called junkyards
They know what years fit into other cars- can mix and match to get you all the things you will need
Stock setup has overtemp limit switches built in- I dont know the details- just what info is in the diy
Old 10-03-2008, 12:07 PM
ill take a look when it is time i could probably just got to the yard at try to grab one off a newer acura maybe 03-08 will all components ha ill test it out on the passenger seat 1st.. only my g/f sits there
Old 08-30-2009, 07:33 PM
Maxfli44's Avatar
Heated Seat Pad Replacement
I have repaired my driver side heated seat pad three times on a 2003 TL. It keeps failing, so I want to replace the seat pad.
Any suggestions on where to get a quality replacement pad other than at the Acura dealership?
Old 09-23-2009, 08:03 AM
southrn03tls's Avatar
wats wrong with just turning the heater on? who needs heated seats? other than fvkin with ure passenger and turning their seat on in the dead of summer. lol
Old 09-23-2009, 08:51 AM
DAiNiUS's Avatar
Because leather gets really cold during winter, just like it gets really hot during summer.
Old 09-23-2009, 11:38 AM
7 Tl's Avatar
wait how do u even turn on the heated seats on a 3.2??????
Old 09-23-2009, 02:37 PM
大日本帝国
Go90go's Avatar
There are supposed to be two switches on the center console next to the shifter.
~Cheers~
MrHeeltoe
20
02-23-2023 01:54 PM
tsx_boy
12-13-2019 08:33 PM
MrHeeltoe
09-29-2015 10:43 PM
hashbrown
09-29-2015 12:13 PM
MrHeeltoe
09-28-2015 05:43 PM
Quick Reply: heated seats
