Heat Issues?
Old Apr 27, 2010 | 12:16 PM
Nov!ce's Avatar
White Type-S
Heat Issues?
Anyone experience lack of heat on their UA3. I get A/C, but when I turn the temp up even to the highest point, cold air still comes through the vents. Also, the coolant/water temp guage is always low. It's either right around the "C" or a lil' above. Never in the middle of "C" and "H'.
Old Apr 27, 2010 | 01:19 PM
Go90go's Avatar
大日本帝国
Burp your cooling system or change your radiator hoses. I had a similar (heat only on hard revs) issue and after changing the upper radiator hose (again) the problem went away.
~Cheers~
Old Apr 27, 2010 | 02:46 PM
Nov!ce's Avatar
White Type-S
~Cheers~
What do you mean by burp? I'll have take a look at the radiator hoses and ask my mechanic to do the same when I get the Type II IM installed and my valves adjusted. Anything else that can be easily done while I'm having that work done?
Thanks.
Old Apr 27, 2010 | 04:49 PM
DUECEON9ER's Avatar
You know clearing out the air in the cooling system just have the mechanic give it a try. Also, look at the heater hose behind the engine near the firewall see if it's leaking or worn out also.
Old Apr 27, 2010 | 08:48 PM
KaMLuNg's Avatar
if your car doesn't seem to warm up... i had this problem.. turned out to be faulty t-stat
Old Apr 27, 2010 | 08:50 PM
TLin401's Avatar
'13 Hyundai Sonata
I had this issue and then I just needed to burp the radiator and then it was fine.
cycdaniel
Dec 17, 2019 10:58 AM
Rachel Lu
Sep 27, 2015 09:53 AM
Skirmich
Sep 19, 2015 04:16 PM
mv01
Sep 15, 2015 10:36 AM
Bahamanurse1
Sep 10, 2015 10:05 PM
