terrible whine.
terrible whine.
Fellow first geners, I have a noticeable whine coming from somewhere around the engine I couldn't pinpoint exactly from where because it whines when im accelerating between 0-20 . Have any of you had something like this & can help me out with a probable cause ?
Thanks....
Thanks....
i couldnt wait & checked again. I narrowed it down to the alternator. It seems to have some kind of chirp when spinning.
can't drive it like this , its embarrasing
Normally those noises are most of the time associated with belts. If your belts arent loose, check the pulleys, rusty old pulleys will do that noise.
I'm interested in a quick fix as well, mine do it but only for a couple seconds on cold start up.
How do you use that soap bar?
Just started having the same issue but only does it when I start the car but seems to quiet down as I drive then stops. Hope its not the timing belts, sounds expensive
Skirmich
09-15-2015 06:41 PM
