Ghost problem
Old Jul 3, 2010 | 01:23 AM
bigwerm187's Avatar
Str8 Home built
Ghost problem
Well today i was driving home when i was on the freeway all of my electronics in the car turned off..!!! an then 2 mins later everything came back on.. but my car was still going with no problem. Then this morning when i wanted to turn it on all my dash lights turned on as i was going to start it then all my lights turned of and the car wouldn't start or click at all. i checked my battery voltage it was fine my terminals are clean all fuses are in good shape. after a little while my car turned on fine so its only done it twice but i would like to fix this problem because its no cool. Has anyone had this problem before..?????
Old Jul 3, 2010 | 03:15 AM
Go90go's Avatar
大日本帝国
Yes, it was from a corroded ground terminal ring. It was tightly on, but that didn't make a difference.
~Cheers~
Old Jul 3, 2010 | 07:01 PM
TexasHonda's Avatar
Faulty keyswitch assembly is likely. Contacts get burnt and loose and electrical problems as you describe happen. New switch is easy fix. Check this forum w/ search for previous posts of fix. Following link is similar and there are many diy's out there.
http://www.visualimpressions.ca/switch/
good luck
Old Jul 4, 2010 | 03:10 PM
tek0neq's Avatar
check your ignition i had same problem and that fixed it
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
