Driveshaft
Driveshaft
Has anyone experienced a driveshaft dissengaging? If so, what was the symptom. A complete loss of drive or just a rough ride or vibration. If drive was lost, was there a grinding noise? Thanks.
I've never had this happen, but from other posts you lose drive. Makes sense as you can spin an elevated wheel w/ other wheel on the ground. Failure to install the driveshaft retaining clip into the receiver can cause the shaft to come loose.
good luck
good luck
StonedCL
53
06-11-2009 04:59 PM
