Replaced Both Driveshaft Assemblies
Old Sep 22, 2006 | 09:23 PM
I have an '02 Type S with 68K miles. My transmission was replaced when the car had approximately 13K miles. I recently had a problem with strong vibration while accelerating between 45 and 60 mph. I recently had a rotation and balancing done, so I thought they may have screwed something up. Took it back in, they did the balancing again, still had the problem. The tech told me that he thought the driveshaft assembly on the left side was bad.
Since I originally bought the Acura 100K warranty, I decided to take it back to the dealer. To make a long story shorter, it seems that both the left and right driveshaft assemblies needed to be replaced.
Has anyone else experienced this? Is this possibly related to the transmission problems a lot of us have had - in some cases, multiple times?
FYI - the service at my dealership (Ed Voyles Acura in Atlanta) couldn't have been better - as always. They gave me a fairly new TL to drive (3K miles), and when they found out what the problem was, they told me to keep it until the parts arrived and were installed. Took about a week to get it done. Back when I had my tranny replaced, they sent me next door to their rental car partner (Enterprise) for a free loaner. I told them that since I was driving a TL, I didn't want to end up in an Escort for a week or two. They hooked me up with a Maxima SE, so the ride/performance were fairly comparable.
Let me know if you've had the driveshaft problem.
Old Sep 23, 2006 | 10:01 AM
fsttyms1's Avatar
Its not related to the tranny problem we have (unles you had it floored and it slipped between shifts and really really slammed into gear, and i still doubt it would cause that)
Old Sep 30, 2006 | 06:46 PM
MotionEffects's Avatar
Acura TLS are SLOW
Was the vibration from side to side? I had my axles replace on my car. The inner cv joint was worn and it had a awkward Side-to-Side shake upon acceleration.
Old Oct 1, 2006 | 02:58 PM
No - it was very similar to the type of vibration you'd get if your wheels weren't balanced, only much more shake and vibration than you might normally feel due to a balancing problem. It almost felt like the wheels were trying to come off.
Old Oct 1, 2006 | 04:32 PM
demolition_x's Avatar
Agean Blue Bishes
wow this is like exactly like my problem...
its posted a few posts down.
i get that same vibration only while under load. if i let off the gas it stops.
any chance your lowered?
Old Oct 2, 2006 | 12:11 AM
03CoupeV6's Avatar
05 C230K & 09 135i 6MT
Ed Voyles is pretty good. The last loaner I got from them was an 06 TSX-Navi. They've always given me new Acura cars.
Old Oct 4, 2006 | 09:12 PM
ICEBLE-S's Avatar
So was it the axle? I'm having the same issue now also. Vibration under heavy accelaration.
SpraykwoN
ILX
Sep 11, 2015 08:45 PM
theinsvnity
Sep 10, 2015 10:22 PM
brjones9
Sep 3, 2015 07:30 PM
DRR98
1G RDX Problems & Fixes
Sep 2, 2015 10:52 AM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
