Driver side door locking problem
Old Jul 30, 2006 | 03:36 PM
DerekTurnbull's Avatar
4th Gear
Hi
I have a problem with the driver side door lock in my 97 2.5TL. When i lock the door, regardless of how i lock it (key or switch) it locks fine but repeatedly attemps to "re-lock" the door. It clicks atleast 3 or 4 times every time i lock it, and sometimes repeats continously until i walk away. Sometimes it clicks a few times, then stops for a while, then after a few mins, starts to click again. It isnt really a bad problem but it is very very annoying and rather embarasing at times.
The acura dealer service department where i live (Victoria BC) says its the motor for the door lock and that i need to get the door actuator replaced. I think he said the part is about $250CDN + labour. Im not an expert but this doesnt seem like a perminant fix for the problem. Whatever is causing the door lock to get caught up or dirty will probialy cause this problem to repeat itself in a few years...
I have heard of this problem on this car a few times but i have never read about any solutions. Does anyone else have this problem? and if so how was it fixed?
A mechanic friend of mine says the problem was most likely the switch/sensor which tells the actuiator the door is locked isnt working properly. I dont want to give my money away to the dealer if it wont solve the problem.
Thanks in advance to anyone who responds.
Derek
Old Jul 30, 2006 | 03:41 PM
4th Gear
hey, i almsot forgot
I am thinking about getting a remote keyless entry installed in the car. I was quorted about $300CDN for the whole job and i was wondering if the locking problem would possiably be fixed if i did that?
Im not sure why these cars dont come with them (only the 3.2 did) but thats another story.
Old Jul 30, 2006 | 04:29 PM
leventis72's Avatar
Derek
First off, welcome to Acurazine you will find alot of info by using the search tab
I have a 97 2.5tl as well with the same problem. This is a very common problem on our cars and to be honest with you dont know why it was never recalled by Acura . The part is pretty damn expensive. Try some online salvage yards or oem acura sites to get a cheaper price. Labor basically consists of taking the door panel off and accesssing the actuatorand removing it . Should take an hour tops and is an easy DIY project. I havent got around to doing mine yet but have replaced many in my time on this model.
Regards
Old Jul 30, 2006 | 04:32 PM
leventis72's Avatar
By the way I installed an alarm-keyless entry in my 2.5 and no it will not fix the actuator problem you are experiencing. Again welcome
Old Oct 30, 2009 | 03:22 PM
bwallace530's Avatar
Hello i have an 3.2 tl and have the same problem it is so annoying. And have no clue how to fix it?????
Old Oct 31, 2009 | 12:52 AM
bigwerm187's Avatar
Str8 Home built
my car does that tooooooooooo.... but i got over it.. lol... if u lock the car from the passenger side it dooesntdo it that much does it like once or twice then it stops.. lol
Old Oct 31, 2009 | 06:51 PM
Yeah i tried that too and it stopped a lil bit or i have sara lock it from the inside when were driving and it does not do it either and one more ? my car does not lock once i get up to speed which is weird u would think that it would do it.
Old Oct 31, 2009 | 07:55 PM
main70072's Avatar
^ Our cars does not have that feature to lock the doors after a certain speed.
Old Nov 1, 2009 | 04:31 PM
I was looking under my steering wheel where the fuess are and there is a lil zip tied speaker under neath it kinda wierd. i dont no if that was so post to be some part of the alarm or not.
Old Nov 1, 2009 | 08:42 PM
7 Tl's Avatar
Same problem here for about a month. The driver side door would lock on its own. But, we all know that on out tl's the door handles are "weak". I dont know if any of you have this problem, but i would find that my door handles would like stick out. What i do, is push my door handle so it would go back in to normal " no my door handles are NOT broken". after pushing them in, i didnt have the door locking problem at all. Therefore i would say maybe that's causing your problem i really dont know. But hey it solved my crazy door problem.
Old Nov 1, 2009 | 09:07 PM
TLin401's Avatar
'13 Hyundai Sonata
Do you guys still have the factory alarm?
That may be the issue if so.
Old Nov 1, 2009 | 09:17 PM
7 Tl's Avatar
yeah factory alarm is still on there. Yea that might be the issue too. But what i heard, is that reason it might do that, is that the sensor thinks someone is actually trying to open the door since the handles are out. Therefore i guess since the alarm/sensor whatever is a security feature, the doors lock on their own, who knows.
Old Nov 1, 2009 | 09:36 PM
TLin401's Avatar
'13 Hyundai Sonata
This should help.
https://acurazine.com/forums/1g-tl-problems-fixes-118/i-need-help-alarm-goin-nuts-708140/
If not check the sensors in the door also make sure that the latches are grabbing the hinges.
Old Nov 1, 2009 | 09:57 PM
7 Tl's Avatar
i dont think the problem would be the stock alarm. what i do is just disable it by opening my door with the key and turning it right, that just about disables the stock alarm. Plus, i would say its extra security lol. But yes, i would say the latches and hinges would be the problem. Your right Tlin 401
Old Nov 1, 2009 | 10:10 PM
TLin401's Avatar
'13 Hyundai Sonata
If you want security then you are better off getting a better alarm.
Try the method that I said and if that doesn't work then it is the latches.
tman570
Jun 11, 2019 07:56 AM
nanos
Nov 12, 2015 08:41 PM
sockr1
Oct 1, 2015 01:31 AM
acuraST
Sep 17, 2015 02:31 AM
Steven Vitek
ILX
Sep 10, 2015 07:29 AM
