differential problem
Old Jan 7, 2011 | 10:02 PM
deejayphilo's Avatar
Theres a gear oil dripping underneath my engine right where the differential connect with the tranny on the right side, by the passenger side. Is that the differential for this front wheel drive? How difficult to remove that?
Last edited by deejayphilo; Jan 7, 2011 at 10:04 PM. Reason: I believe its the output shaft seal...
Old Jan 8, 2011 | 03:16 PM
TexasHonda's Avatar
I would make sure it's not engine oil from higher up draining down. However, if it's gear oil, replacement is a big job. Probably only worth it if the leak is unmanageable w/ periodic topup and you intend to keep the car for some time.
good luck
Old Jan 16, 2011 | 04:57 PM
Its the automatic carrier assembly, its easy to remove actually removing the trans axle will take longer than removing the carrier assembly. I think when I replace the engine my friend uses the impact wrench and over tighten it coz I see crack to were the bolt attaching the tranny.
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
Cexarin
Sep 23, 2015 07:43 PM
