Cel code
Old Jan 10, 2011 | 05:56 PM
7 Tl's Avatar
Cel code
CEL came on, scanned & pulled code 1705 telling me the tranny might be on its last ? uhhhhh, i dont think so. my tranny pulls pretty hard for almost 190k, the tranny has been serviced,& fluid looks pretty clean. Should i service tranny again its only been about a year ?
Old Jan 11, 2011 | 07:25 PM
myisanog's Avatar
i wouldnt . i changed mines every 30 miles . u should drain and fill gear oil though
Old Jan 11, 2011 | 07:34 PM
7 Tl's Avatar
would any of you use any lucas oil stop slip in our trannys? some recomend it but others dont
Old Jan 13, 2011 | 11:55 PM
myisanog's Avatar
no . lucas oil is temporary and will only seal the leak for about a month max, after that the leak will become bigger.
Old Jan 16, 2011 | 07:44 PM
TexasHonda's Avatar
Code 1705 is an electrical fault in the AT gear position switch, switch connector, or switch wire. There is a long diagnostic in the Acura shop manual to look for faults in the switch circuit. Anyone ever spill a soft drink into the console. This is a likely cause of this fault.
Easy fix to locate the fault and replace the switch,...compared to a new transmission or new car.
good luck
Jamus22
Jun 11, 2023 10:08 AM
MilanoRedDashR
Oct 2, 2015 10:49 AM
thegipper
Sep 28, 2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
hrothgar02
Sep 28, 2015 11:08 AM
