debadge problem
Old Nov 17, 2008 | 12:03 PM
andrew070489's Avatar
debadge problem
hey so i debadged my TL and there is still residue from the adhesive.. i removed with a razor blade and goof off i guess not the best idea.. there arent many scratches tho. but how can i get the remaining stuff off and clean it up so it all blends together? i dont have a buffer or whatever its called thanks!
Old Nov 17, 2008 | 12:40 PM
vas25tl's Avatar
The Box
Is there still a lot of adhesive left? I used a plastic razor blade and goof off. Once I got it all off, I put some buffing compound on the trunk and buffed out the scratches..be careful using regular razor blade's, very easy to get deep scratches that later will not come out.
Old Nov 17, 2008 | 12:42 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
You should have used dental floss. For the residue, "Goo Gone" works pretty well, and as stated, use some wax or sealant to finish it off.
Old Nov 17, 2008 | 01:52 PM
bigwerm187's Avatar
Str8 Home built
yeah i did the same thing and that will come of over time. i used a rubber wheel that took everything of but you can see it a little but it goes ways with time.. and i wash my car every weekend and now u cant evern notice it was even there...
Old Nov 17, 2008 | 02:59 PM
thanks guys but i dont have a buffer, ill use goof off and a credit card then what?
Old Nov 17, 2008 | 03:41 PM
R2D's Avatar
R2D
you don't need a buffer or credit card!
Use rubbing alcohol and a terry cloth towel. Poor some alcohol on the terry cloth towel all rub kinda hard and you'll start to see it coming off pretty fast. it's might take some time tho.
I did it this way to my TL.
Good luck!
Old Nov 17, 2008 | 03:54 PM
thanks!!
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
