Crazy Question! How to replace light bulb
Old Nov 21, 2008 | 11:55 PM
Billu99tl's Avatar
Tl fever...cureless!
Hi guys i try to do little search and didnt see how to replace the light bulb on 96 TL..Its my girls car and passenger light just got blown !!! i tried to replace it in dark and it didnt help me ...is it easy or wut i gotta do to replace the bulb ..I already have replacement bulbs
thanks a lot guys!!1
Old Nov 22, 2008 | 11:16 AM
main70072's Avatar
From what i remember, you have to squeeze the sides of the light bulb connector to disconnect it from the bulb itself. Then, there is a rubber cover that has to be removed. You can remove it by pulling on the tabs. Once it's out, there's a clip inside that holds the light bulb to the housing. Undo the cliping and it should come out easily. Make sure when you put the new bulb in not to touch the bulb with your hands or it will burn out prematurely. Install is the reverse of removal. This is also in the owner's manual. Hope this helps.
wusty23jd
Sep 24, 2015 11:41 AM
theinsvnity
Sep 10, 2015 10:22 PM
brjones9
Sep 3, 2015 07:30 PM
pesobreeze
1G RL (1996-2004)
Sep 3, 2015 12:26 PM
Mcj270
Aug 31, 2015 04:45 PM
