coolant reservoir
Old Apr 22, 2011 | 06:10 PM
Roundeye's Avatar
coolant reservoir
Gotta 96 tl with 3.2 and noticed steam coming from drivers side of the hood, from the reservoir. I thought it was the hose from the radiator to the reservoir, so I changed it. Still got steam coming from reservoir. Is the coolant system pressurized on the tl? The steam is coming from the 90 degree nipple in the lid (where the nipple goes in to the lid.)
Old Apr 22, 2011 | 06:32 PM
7 Tl's Avatar
Really? from the coolant reservoir? ...i thought valve cover but this is odd.
Old Apr 22, 2011 | 10:14 PM
TexasHonda's Avatar
There should be a rubber tube from the nipple on cap to the bottom of the reservoir. This allows overflow to blend w/ fluid in the reservoir, and allows fluid to be pulled back into radiator by differential pressure as the engine coolant cools and shrinks in volume. Replace tube and you should be fine.
good luck
spudweb
May 22, 2016 02:39 PM
merc009
Jan 27, 2016 10:34 AM
LeVeL
Oct 18, 2015 04:19 PM
ROSSARONIE
Oct 2, 2015 11:46 AM
Username 0
2G TSX Performance Parts & Modifications
23
Sep 28, 2015 09:09 AM
