03 Transmission 5th/OD issues
Old Apr 22, 2011 | 07:19 PM
Newbie12345's Avatar
8th Gear
Interestingly enough I push the shifter into 4th and drive the acura I have, TL 03 and it's fine. Though if I drive it in OD/5th the car seems to shudder and make a sort of soft rumbling noise you may not hear if you're not a little good of hearing. It's irritating to think though what could that be?
Any clues at all, so I am trying to save money am I losing a trainy...
Well, Thanks in advance!
Old Apr 22, 2011 | 10:11 PM
TexasHonda's Avatar
If torque converter locks up at too low speed, the engine will lug and a rumble/vibration will result. This can be a software fault or hydraulic fault. Check w/ Acura to see if there's a software update for your vehicle.
A drain/replace w/ Honda ATF may help.
good luck
Old Apr 22, 2011 | 10:53 PM
8th Gear
Thank you, it does seem to lug some in between 30 and 40 ... then on and off a rumble and vibration like you speak. I'll do the research....
mada51589
Jan 9, 2025 04:40 PM
pstomps
Feb 20, 2017 03:29 AM
carz0159
Sep 20, 2015 06:11 PM
JDMVP
1G TL (1996-1998)
Sep 17, 2015 06:14 PM
