check engine light
Old Jun 22, 2008 | 08:43 PM
haynTL's Avatar
check engine light
hey ive searched the forums but didnt really answer my question.
if i reset the ecu by disconnecting the negative terminal on the battery will it reset my radio as well? i dont know where the code went so i dont know how to get another one
Old Jun 22, 2008 | 09:36 PM
KrayzieDxC's Avatar
Khmer Pride
yes it will reset..it part of the battery that turns it on..it could be anywhere..check in your glove department for your radio code,armrest,back of your radio,engine fuse box ,manual..
Old Jun 22, 2008 | 09:41 PM
haynTL's Avatar
where would it be in the back of the radio and how would i be able to see it?
Old Jun 22, 2008 | 10:02 PM
KrayzieDxC's Avatar
Khmer Pride
by removing it, there is a thread about how to remove the radio. you going to have to search..did you lose your radio code? and you cant seem too find your code in the spot i said? if you cant you goin to have to get the back of the radio to get the serial # off it and call acura for the code,they will ask for your vin #. or go to ebay and they can unlocked the radio for you but they charge
GL
Old Jun 22, 2008 | 10:24 PM
haynTL's Avatar
yea i had the code on a piece of paper but i cant find it anywhere now. i will be changing out the deck in about 2 weeks so idk if i should just wait or what?
Old Jun 22, 2008 | 10:56 PM
haynTL's Avatar
okay i found the code it was in my house.
i unplugged the battery and the light is now off
Old Jun 22, 2008 | 11:10 PM
01tl4tl's Avatar
for others in this bind: In the passenger footwell is a fuse block- find the one marked CLOCK and remove it for a few minutes-
thats the secret backup power to the ECU and will reset all master warnings and lights.
CEL is a warning of something- get the codes read!- but they will need to show up again now that it was reset
Old Jun 22, 2008 | 11:20 PM
haynTL's Avatar
the light came on because i unplugged like the throttle positioning sensor when i was doing the coolant bypass so the light didnt mean anything
MikeYutkin
Sep 10, 2015 10:13 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
whitesoxsfan12
Sep 7, 2015 04:07 PM
