Car is starting to be very bumpy
Feels like the car starts shaking at about 60mph and under that speed she does not shake at all but over that speed she starts doing it again. I had to pull over today and check to see if my tire was not flat it was shaking that bad and all the sudden a ton of oil is coming out of her again starts leaking every once in awhile it really odd.
How do i check the wheel balance? I just got the car aliened at pep boys in july could it already of went out?
The oil is not leaking off of the oil filter or the oil pan if you were to look down right into the engine bay past the belts and radiator there is some bar or something like that im not sure what it is but it has oil droplets off of it here are some old pictures of the leak above the belts
'13 Hyundai Sonata
That would be your water pump.
That is not good bro.
Get that thing changed immediately. If you don't and the timing belt snaps then bye bye engine.
My car use to shake at about 60 mph then I had my ball joints changed and car aligned and it went away.
How is can oil be coming where my water pump is?
'13 Hyundai Sonata
It cost me $450 for my ball joints to be changed and my car is be aligned.
Do you hear a clunking noise from your car?
If so then it is your ball joints.
No i dont here a clunking noise. But my car just starts to shake alot like so much that my legs start to move. But it goes away comes back. My front bumper was loose i was at the hostipal and the parking bumps i pulled a lil to close to and ripped some rivits off so after i fixed that the bumping stopped but came back again.
Not really a noise at all just a lot of bumping and rattling ever once in awhile.
I here a high piched wine but it is the belts i think i cant really explain the sound i will try to get a video up if i can find out how to.
Yeah right now im looking on buying some off a 99 tl. But not quite sure till i go and look at them. I no the front ones are really really really low on tread so bad that if the steering wheels is cranked i will loose just about total control of the car.
saberlove
03-11-2021 09:29 AM
bearingman07936
01-07-2016 03:22 PM
