brakes...or lack thereof...
sup guys. Just got back after having been on vacation for 6 weeks only to find that the TLs brakes felt weird. When at a stoplight, the pedal gradually sinks further and further to the floor. If I park the car on my driveway and support it with the brakes, it will eventually begin to roll down after a minute or so, and i have to pump the brake again for it to stop.
My instincts tell me its the master cylinder. Can anyone confirm this. What part of the master cylinder assembly am I looking to get in order to fix the problem. Thanks.
TL no more!
Yup. That's the master cylinder. I had the exact same problem. When I come to a stop at a stop light, the braking was good until the car is completely stopped. After that, the pedal sank to the floor gradually. I took it to the shop and they replaced the master cylinder and repainted the brake booster because they said there was some corrosion from the brake fluid. I hope this helps.
TL no more!
In the meanwhile, when you're at a stop light, put the tranny to "N" so the engine won't pull your car forward. That way, the brakes will have some catch with the discs.
Hurricane Game
buy a new one. get one online....for like $115. the kits to rebuild them (if there are any) are usually uber expensive and just better to get all brand new.
thanks for the headsup. How much did it cost u guys to fix, and did u use genuine acura parts or aftermarket. On acuraautomotiveparts, the master cylinder for a 3.2tl (part#1 in the diagram) retails for $212.
http://www.acuraautomotiveparts.org/...prddisplay.jsp
Originally Posted by vishnus11
Thanks a bunch for the link - this is what ill probably end up purchasing.
Any advice on installation such as bleeding procedures?
Brake question/05TL
With only 13k miles...sometimes it seems like the brakes make a crunch sound.....I told the dealer last time I was in..but they didn't find anything...is this sound normal?
...it doesn't happen every time..but I can definitely feel some grinding in the brake pedal when it does happen..what do you think it is?
Hurricane Game
could be metal on metal. if you have any debris that has gotten caught between the pad and the rotor, it could grind. do you feel any shimmy/vibration when it makes that noise? i doubt a 'crunching' sound on any car, let alone a brand new TL, is normal.
No vibration...just notice when I brake..normally you just feel pedal..I'm feeling two things come together..no noise..just feel it in my foot..lol..like maybe it's the brake pads...but at 13k miles?
2007 6SMT Type-S
2007 6SMT Type-S
$150.00 labor to change at local garage. Not bad. I would have done it myself if I didn't need my car working right ASAP. I found a rebuilt lifetime warranty M.C. at Autozone for $71.00 after you take yours back (core charge/deposit was $50.00) FYI
**200 Posts!**
**200 Posts!**
I (the one who started the thread btw) went with LDH's recommendation, and purchased my master cylinder brand-new for $99 from NTP. Worked out great for me, and my mechanic only charged me $50 to put it in!
snorf
11-04-2019 06:44 AM
emailnatec
29
09-28-2018 04:27 PM
oo7spy
Technology
26
09-22-2015 10:01 AM
rockyboy
09-21-2015 10:47 AM
