brakes?
Old Oct 20, 2007 | 11:20 PM
cubanboynumba1's Avatar
3rd Gear
brakes?
i just got a 96 2.5tl i was driven it for a while today and after a while braking started having trouble. if i was going up to a stop sign i would press the brakes and it would slow down but the brake pedal would keep going more in and my car wouldnt come to a complete stop. i just got this for my first car and don't know much about cars so if you can help i would appreciate it.
Old Oct 21, 2007 | 05:01 AM
Go90go's Avatar
大日本帝国
You need to bleed the brakes. If it happens again after awhile, you need to replace the brake master cylinder, which is pretty cheap. A new master cylinder will run you about $100 for the part itself.
~Cheers~
Old Oct 21, 2007 | 07:39 AM
01tl4tl's Avatar
let see- just got the car,,,,- do we really think all it needs is brake bleed?
not likely~ most people sell the car with something failing they dont want to fix
Do this test- if you pump the pedal twice in a row fast- does it increase the feel of pressure under your foot the 2nd time? NO? not air in system
Now with the car in drive, push the brakes down- does it hold the car stopped, does the pedal go weak under your foot and then you have no brakes? YES?
You need a Master Cylinder for the brakes- then you will need to bleed the brakes to remove the air from the lines that got in during parts install
You should be flushing the brake fluid every year anyway
Have a read thru the gen1 thread list and it will answer most questions, then if you need special help you cant find a thread on- start a new one.
Good luck- and welcome to the forum and the acura family
Old Oct 22, 2007 | 09:07 PM
3rd Gear
thanks i went to the garage and they bleed the brakes now they work fine but before the brakes would just keep going further down while i was holding it. but got it fixed and im happy
Old Oct 22, 2007 | 09:51 PM
01tl4tl's Avatar
Keep an eye on it-
air in the lines will make weak pedal, but yours gets weaker as you hold the pedal- thats usually the master cylinder
And there is a reason air got in the system- did the tech have any guess how?
GWEEDOspeedo
Jan 15, 2016 10:39 PM
lanechanger
Oct 13, 2015 10:56 AM
rockyboy
Oct 2, 2015 10:45 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
2ManyHobbies
Sep 24, 2015 09:23 PM
