alternator
Old Nov 4, 2006 | 12:32 PM
crucial24's Avatar
alternator
recently my car battery died so i bought a new one but it seems as if the same issues are arising again! My rpm fluctuates under 1 when im idle and sometimes when i speed up my car speed guage isnt showing me the correct speed it fluctuates as well then the abs comes on and off sometimes u hear a clicking from the engine and then it stops. What might be the cause i asked a friend of mines and he said the alternator. Any other idea?
Old Nov 4, 2006 | 03:20 PM
TexasHonda's Avatar
An alternator w/ damaged rectifier will put out enough voltage to charge the battery, but may cause problems w/ electronics. You need to have a alternator test performed by a good auto electrical shop.
Another possibility is a bad battery connection either positive or negative. Also check primary ground connections to engine and body frame from battery.
good luck
Old Nov 4, 2006 | 10:18 PM
crucial24's Avatar
thx man i will check those things in the morning
Old Nov 6, 2006 | 09:55 AM
crucial24's Avatar
well i found out that it is the alternator but how much shood it cost me i got an estimate for 390 i was like wtf
Old Nov 7, 2006 | 06:23 AM
TexasHonda's Avatar
Remove the alternator yourself and take to an electrical shop for a rebuild. Cost should be <$100 to replace rectifier and voltage regulator. You shouldn't need any other parts such as bearings, rotor, field, etc.
good luck
Old Nov 8, 2006 | 01:03 PM
crucial24's Avatar
u got that rite it was the rectifier and regulator damn thing costing me $200 to fix as we speak including parts an i got a new fan belt as well
Jul 16, 2017 07:33 AM
brboy
Oct 5, 2015 11:34 AM
mars
Sep 28, 2015 11:03 AM
agupta3224
Sep 22, 2015 08:08 PM
