ABS/Odometer
ABS/Odometer
My '96 TL3.2 has about 111,000 miles.
For the last 30K I have been driving with my ABS light on. The dealer wanted $1,800 to fix the problem. Can anyone recommend a cheaper fix - I've heard through the board that there is some kind of chronic problem with the ABS systems on the first gen TLs.
Also, my odometer just quit.... I suspect the cable has gone bad but has anyone else had this particular problem?
if you odometer quits might need a use one or a VSS. or are you talking about your speed?
Search my posts for instructions on pulling the ABS codes.
You can buy used modulators for much less, usuallly < $200, perhaps < $100, if that is the problem. Wheel sensors seem to be more frequently the problem.
good luck
good luck
UPDATE: ABS & ODOMETER
The dealer (Radley Acura) tested the ABS system, bled the line and concluded I need a new ABS Modulator ($1800).
The also decided the problme with the Odometer is the electrics on the ignition, which they want $396 to replace.
Does anyone know where I can find remanufactured or junker parts -- especially for the ABS Modulator -- rather than be bled dry by teh service department?
Check car-part.com for modulator near you. What ABS code/s were found?
Does speedometer and cruise control work? If yes, a used instrument panel is needed. Again car-part.com should allow you to locate one nearby at a reasonable price.
good luck
good luck
well, radley acura changed the speed sensor and that didn't fix the problem... so they said i needed a new speed head (which i bought online from a used car parts dealer)... they installed it for free and it works -- but the did not reset the odometer either to zero or to the mileage on the old one.... AND some of the lightbulbs in the new/old part are out... I can live without the D4 bulb but the TCS light is out, the cruise control light is out and the ABS light is out. And of course Radley wants $$$$ to replace them.... couldn't they have checked them beforte they put them in?
they should have tested everything before they closed it up-=
BUT
if its a part that you brought in- they have no legal liabilty about its function
You can tell if the car is on cruise- your foot should be on the floor- not resting on the pedal- that reduces gas mileage
That ABS light is something you dont ever want to see anyway-it means the system has failed
Learn to not lock the brakes in an emergency- its a basic driving skill!!
The TCS light should flash when the wheels are spinning under 16mph (20kph) and
the system is active- again, something you can feel- if it takes a blinking light for you to notice the engine revved but you're not going up that icy slope.......
As long as the systems themself work- that is the main thing
What about the part they misdiagnosed??- it was not the cure- you dont pay for their guessing
A call to Acura may be in order
1-800-382-2238 x5
BUT
1-800-382-2238 x5
Note- there is no way for them to reset the odometer displays, meant to be tamper proof, and there should be a sticker on your car now that says odometer changed at x miles- new start reading xx,
so that in the future you car doesnt lose 70k miles when you sell it...thats the intent of the system- prevent rollbacks
A specialty speedo repair shop (look in phone book) MAY be able to help you out much better than the dealer now.
You have an older car with problems- go where there is an older guy who fixes problems! The dealer works on new cars that need servicing by the book, and new brakes~
BUT
1-800-382-2238 x5
BUT
1-800-382-2238 x5
BUT
1-800-382-2238 x5
BUT
1-800-382-2238 x5
