'98 TL V6 MAP Location
Old Apr 16, 2013 | 01:58 PM
JFS0650's Avatar
9th Gear
Can anyone point me to the MAP sensor location on a '98 TL 3.2? Thanks in advance.
Old Apr 16, 2013 | 04:43 PM
HP11's Avatar
97 3.2TLPrem(Sold 3/7/14)
Old Apr 16, 2013 | 04:50 PM
JFS0650's Avatar
9th Gear
Thank you. Is this a '97? My '98 doesn't look quite like that, and the part circled doesn't look like the exact replacement part that I ordered.
Never dreamed it would be hidden so well. Any thoughts??
Old Apr 16, 2013 | 04:51 PM
JFS0650's Avatar
9th Gear
Actually, I'm confused. Everything looks the same except for the area right where the sensor is! Argh. I'll look again.
Old Apr 16, 2013 | 05:06 PM
HP11's Avatar
I could be wrong but I thought that 96-98 were the same.
Old Apr 16, 2013 | 11:55 PM
jrot's Avatar
your car doesnt have the traction control. the one in the pic does. it will be in a similar location.
Old Apr 17, 2013 | 12:07 AM
Ken1997TL's Avatar
Exactly.
Only the intake and ECU are different in the TCS/No-TCS cars.
Old Apr 17, 2013 | 07:50 AM
HP11's Avatar
I notice that a lot the 'aftermarket' ones like what you'd get from Autozone, OReilly, etc. have only one mounting ear while the OEM has two.
Old Apr 18, 2013 | 01:47 PM
HP11's Avatar
I notice you asked the same question over on Acura Forum. That site is deader than this one when it comes to 1 gen TL's so don't expect much there. You know what it looks like, right? Shouldn't be that hard to find. It's on the pipe between the air cleaner and the throttle body. Mine only looks different in the picture becuse, as mentioned, yours doesn't have traction control. Why do you think you need to change it? I seldom hear of those going bad. Rather expensive part to throw at an unknown problem.......
Old Apr 18, 2013 | 08:27 PM
jrot's Avatar
yeah man, thats pretty rare, and some times when that code reads from the obd2 its something else causing it, like a split hose or vac leak...and its pretty simple, if yours has one hole and the aftermarket has two then its the wrong part, something somewhere isnt right in what you or the parts guy are looking for.
Old Apr 18, 2013 | 09:55 PM
HP11's Avatar
Originally Posted by jrot
.....if yours has one hole and the aftermarket has two then its the wrong part, something somewhere isnt right in what you or the parts guy are looking for.
It's the other way around; OEM-2 holes, aftermarket-1 hole. The one I pictured in post #9 isn't the right one for a 3.2 but that's pretty much what it looks like.
Old Apr 19, 2013 | 08:00 AM
jrot's Avatar
point is the parts are the same or they arent. one is right one is not. thats all i meant.
vpasla1
Sep 17, 2016 07:24 PM
MetalGearTypeS
Aug 29, 2016 08:28 PM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
soupi
14
Nov 15, 2015 11:15 AM
malvothegreat
2G CL Problems & Fixes
Sep 29, 2015 08:00 AM
