'98 TL V6 MAP Location
I notice that a lot the 'aftermarket' ones like what you'd get from Autozone, OReilly, etc. have only one mounting ear while the OEM has two.
I notice you asked the same question over on Acura Forum. That site is deader than this one when it comes to 1 gen TL's so don't expect much there. You know what it looks like, right? Shouldn't be that hard to find. It's on the pipe between the air cleaner and the throttle body. Mine only looks different in the picture becuse, as mentioned, yours doesn't have traction control. Why do you think you need to change it? I seldom hear of those going bad. Rather expensive part to throw at an unknown problem.......
yeah man, thats pretty rare, and some times when that code reads from the obd2 its something else causing it, like a split hose or vac leak...and its pretty simple, if yours has one hole and the aftermarket has two then its the wrong part, something somewhere isnt right in what you or the parts guy are looking for.
It's the other way around; OEM-2 holes, aftermarket-1 hole. The one I pictured in post #9 isn't the right one for a 3.2 but that's pretty much what it looks like.
MetalGearTypeS
08-29-2016 08:28 PM
08_UA7_Gr33k
02-11-2016 02:17 PM
soupi
14
11-15-2015 11:15 AM
