98 2.5 TL MPH gauge going from 60 to 0 in one sec
Old Jan 14, 2008 | 05:19 PM
Chianna7's Avatar
I am having a problem or something with my MPH gauge on my 98 2.5 TL. I was riding on the highway and my MPH gauge went from 60 to 0 in one second and went right back up to 60. I didn't decrease in my speed limit, so I am wondering what could be going wrong. It has been occuring a lot lately. Please help!!
Old Jan 14, 2008 | 05:25 PM
01tl4tl's Avatar
I am guessing your speedo runs off a cable drive and it needs grease or the gears are wearing out
Look in the phone book for speedometer repair and call them
On my truck- it was a simple remove and grease the cable to fix a prob
Old Jan 14, 2008 | 05:27 PM
Chianna7's Avatar
Thank you I will try that!
Old Jan 14, 2008 | 05:31 PM
KaMLuNg's Avatar
it sounds like your speed sensor might be going... that happened on my legend... the speedo would bounce while i was driving then i would get a CEL... after i changed out the VSS, all fixed...
Old Jan 14, 2008 | 05:42 PM
Chianna7's Avatar
Hello KaMLuNG,
I am not familiar with the codes, and I hope to not sound stupid. What is a CEL and a VSS?
Old Jan 14, 2008 | 08:32 PM
TexasHonda's Avatar
If you have no Check Engine Light (CEL) and speed control is working, the Vehicle Speed Sensor (VSS) is not the problem. More likely a faulty instrument panel gauge or circuit board. A used panel from a salvage yard is most cost effective repair.
If you have a CEL and speed control does not work, the VSS is almost certainly problem.
VSS is conveniently located underneath the intake manifold and oil filter. It's possible to do w/o removing anything, but challenging.
good luck
Old Jan 17, 2008 | 07:01 PM
rahgir's Avatar
How many miles on your motor and when did you last change the timing belt? If your belt is slipping, I think this could happen, same thing happened in my 96 prelude for a few months before the timing belt snapped and long story short, i miss my baby
joflewbyu2
Aug 18, 2019 10:38 PM
CL-S progression 01
Jan 26, 2016 04:15 PM
swany0095
2G TSX Performance Parts & Modifications
Oct 7, 2015 02:18 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
johnpancakes014
Sep 27, 2015 12:58 PM
