1999 TL Problem
1999 TL Problem
My 1999 TL starts, runs for a few minutes then completely shuts down. After a few minutes, it will start back up, run a few minutes again and then shuts down again. It is not over heating, at least according to the temp gauge. If I have the AC on, it shutsdown even quicker. Any ideas?
You should post this in 2nd Generation TL Forum to get a faster answer.
sounds like an ignition problem. the electrical portion of the ignition switch had issues on those. they would intermittently not start, or start, stall out, and restart. i would check there. hope this helps. could also be a bad main fuel pump relay.
Received 6,470 Likes
Moved to the 1st Generation Forum for you.
SidhuSaaB
05-30-2020 12:40 AM
Fool
03-10-2016 08:42 PM
