Lights dim abs light comes on wont hold charge
Hello! Have a 96 2.5TL and just replaced altenator,battery and belts due to issues of lights dimming, abs light coming on, car wont hold charge and dies. Hear a clicking sound near passenger side, when try to use power window the lights dim and abs light comes on. Have had to jump the car almost daily. Radio dies when driving and lights will dim.
At a loss at this point!
Any help would be greatly appreciated!!
大日本帝国
Change the negative terminal. Use a battery post cleaner brush to expose fresh metal before you put on the new terminal, as well. Also check that the chassis ground is clean and free of corrosion. That should solve your issue.
~Cheers~
~Cheers~
mada51589
05-03-2022 08:54 PM
rockyboy
01-25-2016 06:00 PM
