1997 3.2 TL SRS light
4th Gear
The SRS light just came on. Does anyone know what can cause this and any possible fixes? The car has just over 300k miles but is still running strong.
damn bro you have a lot of threads already, use the search button and start doing some homework this is common problem so will see a lots of threads with this problem and how to fix it
I have a first gen (1997) 3.2TL and our MES reset yellow plug is not the one plugged next to the fuse box!!
See image below for the correct location. Just remove the 2 screws to detach the cover hiding this and it's a breeze after that.
Hope this helps, I was running in circles with all the other pictures/locations posted for similar models.
To reset the SRS light:
1. Bend a paper clip into a 'U' shape to create a loop
2. Disconnect the yellow plug shown below under the steering wheel and insert the paper-clip into the plug that is now hanging there to complete the circuit.
3. Turn the ignition on and the SRS light will stay on for 6 seconds, then go off - disconnect the paper-clip within 4 seconds after that and the light will come back on.
4. Reconnect the paper-clip within 4 seconds and the SRS light will go off again.
5. Within another 4 seconds of it going off, disconnect the paper-clip and the light will blink twice and it will be done.
mugen_kid
11-13-2015 10:38 PM
Mike Bertram
09-10-2015 09:27 AM
asahrts
09-04-2015 05:55 PM
