Type II...
Old Nov 16, 2009 | 02:48 PM
tmnhs81's Avatar
Cool Type II...
I got one and its already in my car...
Big thanks to Ken (desired_speeds) who did all the work from taking everything out to putting Type II in. Didn't take any pics yet but will post some as soon as I get home. (typing this from work.) Pics coming soon..
Sounds incredible, took my friend for a spin and he was surprised how it pulls at higher RPM's now..
On my way back home last night I rolled the windows down in the tunnel and punched the gas, what an awesome sound it makes now and definately feel the power at higher RPM. Now just waiting for the civic Short RAM to finish CAI..
Old Nov 16, 2009 | 03:04 PM
Ken1997TL's Avatar
Welcome to the Club!
Old Nov 16, 2009 | 03:35 PM
Go90go's Avatar
大日本帝国
Aw... No recognition!! I helped, and was the mediator!! Haha!
~Cheers~
Old Nov 16, 2009 | 03:52 PM
tmnhs81's Avatar
^yea, I forgot that word at the moment when I was typing that... So yeah Arthur being the one who arranged everything, I just drove my car there and let them do it.. and He drove his car to get the pizza... I liked that pizza..
Old Nov 16, 2009 | 03:54 PM
tmnhs81's Avatar
Thanks.. I took my car to work today. Loving that sound... I hope I won't blow anything. Pray for me..
Old Nov 16, 2009 | 04:25 PM
Go90go's Avatar
大日本帝国
You'll be fine since we didn't Mickey Mouse anything.
~Cheers~
P.S. Don't forget me sitting in your engine bay, lifting the mani out, haha!
Old Nov 16, 2009 | 04:34 PM
desired_speeds's Avatar
the engine bay fit you like a glove.
ohh yah, run maybe 1/3 - 1/2 can of seafoam in there and change out the plugs. Throw the rest of the can into the gas tank, those injectors were pretty dirty.
Old Nov 16, 2009 | 04:38 PM
TLin401's Avatar
'13 Hyundai Sonata
Congrats.
But because this is Azine I have to do it...
Old Nov 16, 2009 | 05:46 PM
KaMLuNg's Avatar
i concur, and the title is deceiving... this is just the IM right?
Old Nov 16, 2009 | 06:03 PM
Go90go's Avatar
大日本帝国
Yes, just the IM. We still have smog considerations, unfortunately.
~Cheers~
Old Nov 16, 2009 | 09:42 PM
KrayzieDxC's Avatar
Khmer Pride
hmmm i gotta give this a try too
Old Nov 17, 2009 | 04:44 PM
tmnhs81's Avatar
Pics are up...
While installing...
Missing Type II badge. If anyone have one please let me know...
After I put the Legend engine covers on..
Old Nov 17, 2009 | 06:21 PM
tmnhs81's Avatar
~Cheers~
Yea I should have taken a pic but it was too dark and TOO FREAKING COLD. I am sick right now..
Old Nov 17, 2009 | 08:08 PM
Mandy's Avatar
98 3.2 Flamenco Black
Sorry, something good happened here, just do not know what it is...
Old Nov 17, 2009 | 08:22 PM
Go90go's Avatar
大日本帝国
^ He got a new Type-II intake manifold.
~Cheers~
Old Nov 17, 2009 | 08:33 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
Old Nov 17, 2009 | 10:00 PM
TLin401's Avatar
'13 Hyundai Sonata
That looks sick!
Congrats!
Old Nov 18, 2009 | 03:31 PM
bwallace530's Avatar
Sense I am planing on doing this just a lil tight on money right now. I noticed that you moved some things compared to the old intake mani, there was a lil sensor on the top in the middle of the stock one where did you relocate that sensor or did you just take it off?
Old Nov 18, 2009 | 07:59 PM
he had to relocate it when he put in the legend strut bar.
Old Nov 18, 2009 | 10:00 PM
So here's the deal. When you swap intake manifolds, you have to swap the fuel injectors studs from the TL intake manifold. TL fuel rails will not fit on the legend studs. The legend manifold also needs an additional O-ring used as a spacer for the fuel injectors in the manifold. The TL has this extra spacer casted into the intake manifold from factory. This spacer is the O-ring lowest in the entire stack of fuel injector O-rings when you look in the Legend parts diagram. You SHOULD replace all of the injector O-rings and clean the build up off the injectors while you have everything apart. Do not risk putting old injector O rings back on if they have not been replaced recently because they can easily fall apart causing a fuel leak which could lead to a fire. I would highly recommend reserving a lot of time just for cleaning the intake manifold and intake ports in the heads. I was unfortunately unable to do a great job cleaning out the manifold before installing it onto Tony's car, but his manifold was not very dirty. Also, do not forget to take apart the EGR chamber and clean it out, including the pipe. It's a PITA to do it on the car with everything put back together. The Felpro intake manifold kit did not include a throttle body gasket, EGR camber gasket nor EGR pipe end gaskets. You must buy one of each separate, besides the EGR pipe gaskets which requires two. Felpro makes a throttle body gasket. I'm not sure if they make the EGR camber and pipe gaskets, but I would recommend getting these from the dealer. A gasket for the air suction pipe may also be needed depending on if you unbolted it or not. All 12mm bolts/nuts on the intake manifold should be torqued to 16 ft/lbs while all 10mm bolts/nuts should be torqued to 9 ft/lbs. There is no need to use any sort of silicon or sealant in addition to the paper or plastic gaskets.
Old Nov 19, 2009 | 10:25 AM
Okay, Yeah i got my intake cleaned at a machine shop so thats all good. but now im starting to second guess doing this. I have no clue really how to Does any1 live near chico ca that could help me out???
Old Nov 19, 2009 | 02:24 PM
tmnhs81's Avatar
Ask Ken if he can help you out but you gotta drive up to teh city... He knows what is he doing and there are few other helping hands too out there... If you guys letme know ahead of time I am down too..
Old Nov 19, 2009 | 02:26 PM
tmnhs81's Avatar
Type II intake manifold. Its a nice addition to the mod list..
Originally Posted by princelybug
Originally Posted by TLin401
That looks sick!
Congrats!
Thanks.
Old Nov 19, 2009 | 03:09 PM
Mandy's Avatar
Now I get it....me slow...
Old Nov 19, 2009 | 06:10 PM
KrayzieDxC's Avatar
Khmer Pride
any part # list ? of what to get
Old Nov 19, 2009 | 06:22 PM
TLin401's Avatar
'13 Hyundai Sonata
Revival of the Type II manifold!
Old Nov 20, 2009 | 10:34 AM
Yeah that would be nice but i only have one car and work grave yards
Old Nov 22, 2009 | 02:48 PM
I'll try to put together a parts list when I get the time. But FYI, I still have 1 Type II intake manifold avail if anyone is interested.
Old Nov 22, 2009 | 06:34 PM
undyroos's Avatar
interested, PM me how much...
Old Nov 22, 2009 | 06:35 PM
TLin401's Avatar
'13 Hyundai Sonata
I wish I could do something like this to a 2.5
Old Nov 22, 2009 | 10:41 PM
tmnhs81's Avatar
Its worth it undyroos.... Its worth it.......
Old Nov 23, 2009 | 06:57 PM
undyroos's Avatar
what did you guys use to block off the pair pipe?
Old Nov 23, 2009 | 09:29 PM
tmnhs81's Avatar
I dunno..Ken and Art did all that.
Old Nov 23, 2009 | 10:38 PM
undyroos's Avatar
apparently we don't have a pair pipe so it's an even simpler DIY...
just got my type II intake manifold and front strut bar from ken's friend
cleaning the IM now...pics will be up later...
Old Nov 23, 2009 | 10:40 PM
TLin401's Avatar
'13 Hyundai Sonata
Undyroos you doing this mod tonight??
Old Nov 24, 2009 | 12:08 AM
undyroos's Avatar
just cleaning the IM tonight. did as much as i could with some simple green and a toothbrush. i'll get some wire brushes and carb cleaner tomorrow and finish it off. right now i have a million little cuts on my fingers and knuckles from the sharp edges of the IM and simple green BURNS.
Old Nov 24, 2009 | 12:39 AM
tmnhs81's Avatar
sweet.... Good luck with the install and waiting for some updated pics of your ride..
Old Nov 24, 2009 | 12:55 AM
undyroos's Avatar
at what RPM do you feel a difference now? throughout the range or only in the upper rpms? describe the difference...
Old Nov 24, 2009 | 02:37 AM
undyroos's Avatar
So here's the deal...I would highly recommend reserving a lot of time just for cleaning the intake manifold and intake ports in the heads...A gasket for the air suction pipe may also be needed depending on if you unbolted it or not.
When you cleaned the intake ports did you just let all that crap fall into the runner? I'm guessing it gets burned up one way or another?
This is the diagram for a TL intake manifold. I need gaskets 2, 3, 5, 7, and 9?
This is the TL EGR valve. I need 2, 6, 8 (2 of them), and 9?
This is the Legend Fuel Injector diagram. I need 4 (6 of them)? They're called injector insulators. There were some stuck in the Type II IM, one was hard, I'm assuming that's the seal ring (#2 in the diagram), and the other was squishy, I'm assuming that is the insulator (#4)? Can you confirm?
Which one is the air suction pipe? I didn't see it in any of the TL or Legend diagrams.
Thanks Ken!
Old Nov 24, 2009 | 07:33 AM
Blazing GT's Avatar
good job...post some videos
