secret weapon intake from weapon r
hey im kind of new to this forums and i was wondering how much hp gains can i expect from this intake. is the gains noticable and does it make the car have a deeper tone to it?
You mean the Ram-Air attachment for $80? It's ok if you don't mind cutting a rectangle into your bumper. I did a cold-air conversion on mine using a 2001 Civic EX intake I had lying around. I still haven't gotten around to cutting the pipe down as it's causing the filter to rub against my right winker. Too much shit going on and a bit of a pain to find a 3" pipe cutter from somewhere else other than Harbour Fright.
~Cheers~
~Cheers~
You mean the Ram-Air attachment for $80? It's ok if you don't mind cutting a rectangle into your bumper. I did a cold-air conversion on mine using a 2001 Civic EX intake I had lying around. I still haven't gotten around to cutting the pipe down as it's causing the filter to rub against my right winker. Too much shit going on and a bit of a pain to find a 3" pipe cutter from somewhere else other than Harbour Freight.
~Cheers~
~Cheers~
hey i just got my secret weapon intake today and it was kind of an easy install but the tcs nipple piece broke off but i epoxied it back on and the hose that connects to the intake manifold was to small so i had to buy a new one. i have a question, where is the bracket that comes with the kit suppose to hook up to?
also the intake sounds great idk if anyone else has it but when i let off the gas i can hear a little burping sorta sound when letting off the gas. how do i hook up the cold air tube since i got it for free? any pics to show how or a write up?
Cold air tube? You mean the Ram-Air kit that Weapon-R has? That requires cutting into the bumper. The bracket can be bent and bolted pretty much anywhere. Search for "Cold-Air Finally" and you'll see my thread on how I did mine. Pics were included there.
~Cheers~
~Cheers~
rcs86
08-02-2016 06:52 PM
