legend gs intake
Type II cams should be used in parallel with Type II ecu and Type II FPR for maximum benefit. But if you've done all that work already on type I heads, you might as well swap to full type II heads and save some hassle. The result of just type II cams alone on a type I motor is unknown. As far as I know, you should expect less low end torque and more top end horsepower if you use the cams, although it doesn't help very much if your shift points are still in accord with the type I setting.
Mike, you forget that I have a rear sway bar, and no welding was necessary. The only thing that needed to be done was to slit the new bushings to fit into our factory bracket. The endlinks fit fine.
I'm using a Tanabe one, BTW:
https://acurazine.com/forums/1g-tl-tires-wheels-suspension-103/rear-sway-bar-arrived-yesterday-644271/
~Cheers~
~Cheers~
~Cheers~
~Cheers~
Im having the type ii cleaned before i put it in. Im still waiting for my gaskets to get here. Hopefully i can start putting her back together tomorrow.
My injectors are So gross! And so are all the "secondaries"
its not ALL oil, lol. I sprayed some degreaser on there before the picture. it is nasty though, isnt it? The butterflies werent any cleaner.
The legend intake is being chem-tanked right now.
Will my old plastic engine cover still go over the new manifold?
Only one side was slightly larger, so no point in switching them out.
Yes, it should be fine since you're still running the original fuel rails, and that's where the cover bolts on.
~Cheers~
~Cheers~
