gauge cluster led's?
http://www.elgauges.com/index.asp?Pa...TS&Category=39
these are sick!!! I just put them in.. will post pics shortly.
Originally Posted by copy252
how long did it take and was it rediculously hard? im almost scared to try my self seeing i might freak out if i get jammed up
No actually, it was quite easy. Took maybe an hour and a half or so.
Originally Posted by NyRider
Those gauges look sick
Can U post a DIY was there any kind of wiring you had to do?? from 1 to 10 ten being the hardest you rate this to be??
https://acurazine.com/forums/showthread.php?t=94039
That will get you to the point where you can remove the guage cluster.. just unplug the harneses, and remove the instrument cluster from the dash.
From there it is still rather easy, the cluster face comes apart in two stages; the clear cover, and the black guage surround; these pieces come off quite easily. Once the guages are exposed, just unscrew the tiny phillips screws holding the guage faces in place. Lay the new guage face directly over the existing ones; this takes a lil bit of maneuvering to get the new faces around the needles,(I must say, that was the most difficult part... I was afraid I was going to bust the needles), but it was easy enough. when your done, reassemble everything, and wire.... Presto! You will then have nice new guages.
Oh and P.S.....
I also removed the 2 bulds on the upper part of the guage cluster that shine down on the guages themselves, they are located on the back of cluster nearest the top, 1 over tach, and 1 over speedo.
Thanks! Punched my girlfreinds mom boyfreind in the face for putting his hands on my girl and broke his eye socket sadly I broke 3 knuckles in the process rendering me out of work for a while so I've been bored out of my mind. Got my T.L put up in the garage for the winter so Im doing whatever I can do to it. This will be a definite MUST DO
Thanks again
Does the new cluster fit in with the rest of the dash?
Just from those pics it looks like the cluster may be too 'modern' of a look to fit in with the rest. Is there much of a conflict between the dark gree dash lights and the bright gauges?
If possible could you hit us up with a pic of the whole dash?
my question is... hows the needle vision at night with out the bright ass light from god beaming on your gauges!! lol. i mean those gauges are awesome and im putting mine in. i just wanna make sure ill still see my needle tho
i gave up on reverse glows seeing every set i buy (2 of them now) the friggin speedo gauge doesnt work (I HATE PROCARPARTS.COM) ima get some blue replacement leds from my boy bryan at tec-toyz.com soon as find out what sizes ill need. i wanna change the back of the gauges and the take out the top 2
They were working a treat. I had IPF bulbs from Japan, though. Anyhow, save your money and don't get the white faced guages. My buddy searched and searched and managed to fine a black-faced version and it was clean as hell. The white faces don't look good on our cars...
~Cheers~
~Cheers~
thanks for the replay go90go. Did you also remove the top two bulbs or did you leave all of them in place? And would any 194 bulbs work then? I'm thinking about getting these:
http://www.cardomain.com/item/APC504072B
or these
http://www.cardomain.com/item/PIA19283
or these
http://www.cardomain.com/item/PIA19261
or these
or these
I originally removed them, but it made it a pain to see the needles so I put the stock ones back in. Before I put them in, though, I coloured them with a blue marker to dim the light output and they came out great!
~Cheers~
~Cheers~
http://cgi.ebay.com/ebaymotors/10-x-...05674417QQrdZ1
Will these fit in the gauge cluster? What about behind the climate control?
White bulbs or blue??? Thats the question!!!! I'm ordering some white ones now, yea... i'm a late night shopper, Andbody got pics of blue bulbs? GOgo I know you have blues in your cluster but I've never seen a good shot at them.
Anyone know what bulbs are in the back of the climate control? Theyre really small and i doubt anyone makes leds for it but Its worth asking. I have the 194's and I'm ordering the 37's for the shiftgate soon.
Plan to get something like these, http://cgi.ebay.com/ebaymotors/2-HID...spagenameZWDVW, The hvac lights are small as hell, I don't think a 37 or 74 will fit in thier.. But I'm probally gonna try anyway.
See if it looks the same as the light behind the ashtray and in the shift-gate to see if they're the same. If they are, they're 74s. BTW, I found a pic in one of my phones of my gauges when my car was up. I'll try to post it soon.
~Cheers~
~Cheers~
Here's the pic, it's before I put the overheads back in so it was a bit of a pain to see the needles. Sorry for the lines, that's what you get for wiping the lense with your finger, haha.
Here's what it looked like when I pulled people over:
Haha, I wish I were a cop. Maybe I wouldn't have so many tickets if I were one! If you look towards the bottom left in the second pic, you can see my trunk lighting. So blue that florescent things lit up as if under a black light.
~Cheers~
~Cheers~
Mine are IPF 6 chip ones. $60 a pair. Similar to these, but with 2 additional chips:
I don't mind showing that plate on since it isn't mine, haha,
. My lights, my car, not my number.
~Cheers~
P.S. You can pick up the ones shown here, here: http://www.intakeone.com/Light_bulbs...P1X_168LED.htm
. My lights, my car, not my number.~Cheers~
Mine are done and in with the white inverted led's. I never knew that the top two were 37's they HVAC controls probaly are to so I'm gonna get 6 37 led's and see if I can do the HVAC, shift gate and maybe the top of the cluster. Light output looks nice in the daytime, I haven't seen them at night yet but I'll try n get pics later.
