Window Issue: I'm stumped
Ok when I first brought the car the rear pass. window would work then stop then work, now been stopped for 4weeks. The window would just nug up a hair and not go down when it was stopped.
So today I was installing a motor and regulator. I tested the M/R on the other window to make sure it was working. I moved on the up and down. Good. So I tested the switch on the other window which works. Window goes up and down.
Now I have a good switch and regulator. Took the M/R out and it was indeed locked up. So I installed the regulator and what you know it does go down.
I think it has to be the wiring. Just my luck. What you guys think?
Let me clear it up.
My window will only go up. Not down. I replace the motor and regulator with a working one and still have the problem. I replace the wire harness in the door. And use a working switch. Problem still there. What next?
xsilverhawkx
09-28-2015 06:51 PM
AcuraKidd
09-25-2015 11:18 PM
