where does this go?
Old Jul 11, 2012 | 08:52 PM
jrot's Avatar
where does this go?
found this vac line just hagin out in the bay open on one end, kinda wondered where to hook it up to. it runs to the underside where i cant see, and i dont see another open end near it
and is this my egr?
Old Jul 11, 2012 | 10:10 PM
Go90go's Avatar
大日本帝国
Should be the transmission breather tube, and yes, that's the EGR.
~Cheers~
Old Jul 11, 2012 | 11:11 PM
jrot's Avatar
ok trans breather. so should be left open or does it need to run somewhere? how hard is it to replace the egr? doesnt look hard at all to me, but i was reading the intake has to come off? also ive got an abs light on so is it ok if i just pull the fuse? and if yes then do i pull the two or 3 little one and the big one or will just the big one be ok?
Old Jul 12, 2012 | 01:32 AM
Go90go's Avatar
大日本帝国
Leave it be.
EGR shouldn't have to be replaced. The pipe that leads to the manifold and the chamber inside the manifold is what gets clogged up with carbon deposits, and that's what needs to be cleaned. Doesn't hurt to take the top half off to shoot some brake parts cleaner into the hole, though.
~Cheers~
Old Jul 12, 2012 | 09:11 AM
jrot's Avatar
awesome, so that is what i was reading about that needs to have the intake off to be reached and cleaned properly?? cause i do have a CEL for the EGR.
Old Jul 12, 2012 | 12:11 PM
Mandy's Avatar
98 3.2 Flamenco Black
Best thing is to get it to a shop. They will have to tear down the EGR plenum and clean it.
Old Jul 12, 2012 | 01:04 PM
Go90go's Avatar
大日本帝国
If you've got the time, then yes, take the manifold off and apart to really clean it out. You can do it by hand like I did for my Type II, but you'll need patience, and a LOT of brake parts cleaner. You'll have to scrape/pry out the carbon. That stuff is so black, too, that it's even difficult to photograph, haha. I'll look for the thread for you.
If a shop does it, be prepared to pay them a lot of money to have them hot-tank it, but it will come out as new.
~Cheers~
Old Jul 12, 2012 | 01:10 PM
Go90go's Avatar
大日本帝国
Here's the post where I had the photos. I took out the other ones that don't apply here:
Originally Posted by Go90go
What started as a pretty good day, as good as being having the flu can be:
Yes, that's a Type II.
~Cheers~
That's a Type II manifold from a Legend that apparently only had 90K miles. My 236K mile manifold wasn't nearly as dirty, so I can only wonder what that guy did to his car.
~Cheers~
Old Jul 16, 2012 | 10:12 PM
jrot's Avatar
that looked a little more involved than i though. eeeeeek
