Water not draining?
Old Oct 7, 2004 | 05:17 PM
UnsanePyro's Avatar
Registered Driver
Water not draining?
Over the time owning my car its only rained a few times, and I wash it quite often, but usually don't end up driving it for a little while after. I noticed a couple weeks though after it was parked in the rain, I was driving and going around a left hand turn, and when I did I could hear a good amount of water sloshing to the right hand side, and then back to level out when I got back onto straight road. Went out today after I washed it, and notcied that there is defiantely some water that isn't draining from the front of the car somewhere. I opened the hood and nothing was wet, but I couldn't find any drain holes/pipes witht he short time I had.
Is this supposed to happen and I'm just not used to it, or is it something I should look farther into?
Old Oct 7, 2004 | 09:11 PM
KaMLuNg's Avatar
u check the trunk in ur spare tire well??? that is usually a suspect
Old Oct 7, 2004 | 09:53 PM
spooky3ce's Avatar
Swift 3 B-A-N-G-E-R
Definatly, look into it further... worst comes to worst... you don't look into it and then your TL is gonna have some major body work to be done... its best to find the problem now... let us know whats up maybe we can prevent it on our TL's... sorry to hear about it though...
spare tire well is definatly the best place to look first... if its not there... worst case senerio, its in the space where your sun/moon roof goes into when its open... drive around with the sun/moon roof open and see what happens... good luck on finding the water...
Old Oct 8, 2004 | 05:45 AM
theloweman's Avatar
2005, Acura TL, 5AT
I found water in my trunk today after some recent rain. Didn't find much, just enough to make my trunk carpet damp. Does anyone know where this water comes in from? Is it the tail lights??? Please help.. Don't want my TL to rust away...
TLM
Old Oct 8, 2004 | 08:18 AM
AC_DADDY's Avatar
ballin and baldin
the seals on the tailights on the first gen. TL are defective and should be replaced
i need to do mine. i garage keep my car but when it rains hard the tailight will get some condensation build up
Old Oct 8, 2004 | 09:54 AM
spooky3ce's Avatar
Swift 3 B-A-N-G-E-R
check for any seals that may be broken or torn... and you've found your problem... either your tail light seals like AC_DADDY said or your trunk seal... the black rubber thing that lines the trunk...
Old Oct 8, 2004 | 04:26 PM
theloweman's Avatar
2005, Acura TL, 5AT
Has anyone else actually found water in thier trunks like this?? I know I have owned a honda accord that had this same exact problem... I never could find where the water was coming from...
TLM
Old Oct 8, 2004 | 04:49 PM
UnsanePyro's Avatar
Registered Driver
Guys, I said front :\. Nothing inside the car or inside the engine bay is wet, it just seems to me like the water takes a long time to drain if you get a lot on the windshied without the car moving. It all starts to flow down off the windshied, and down through a couple small holes, and the holes aruond the windshield wipers, but doesn't seem to come out the bottom of the car as fast, like the bottom can't flow as fast as the top, but its all coming out after some driving. I wish I could start taking it apart and looking at it but its a sort of awkward spot to work around, and the stuff was rivited in, not screwed
Old Oct 8, 2004 | 05:07 PM
myfirstAC's Avatar
When I first bought my TL I found water in my trunk by the spare too!! I took out the plug to drain the water and cleaned out the area. I cleaned out the seal (black linin around trunk) just to be sure. Everytime it rained I checked to see if more water had built up but it never did. Not sure if it was the cleaning I did or not.
Old Oct 14, 2004 | 09:55 PM
UnsanePyro's Avatar
Registered Driver
I got out of work tonight (5-10:30) and it had rained durring my shift, but wasn't raining for the last part of it, not exactly sure how long though. I started to drive off and definately heard water sloshing around at first, it was all gone by the time I got home (just a couple miles, prettymuch straight at 55MPH). It's definately the front end also. Maybe I need to talk to the dealership
Old Dec 7, 2004 | 09:48 PM
naba2002's Avatar
i ve had water in the trunk, so much that it spilled into the back seat carpet. i got all the water out and cleaned the seals and put them back on , alot less water now but still getting some . is changin the lights thin gonna fix it guys? anyone? plz help!
Old Dec 7, 2004 | 09:57 PM
Ken1997TL's Avatar
Yeah, I need to fix my left taillight tomorrow, it has some condensation in it.
Old Dec 7, 2004 | 10:02 PM
UnsanePyro's Avatar
Registered Driver
Ken, what parts do you need (part number for the seal?)
Old Dec 7, 2004 | 10:04 PM
Ken1997TL's Avatar
Not sure yet, I need to take a look in there first.
When I figure it out, I'll let you know
Old Dec 7, 2004 | 10:26 PM
UnsanePyro's Avatar
Registered Driver
Awesome, thanks, I need to do one of them.
If anyone is wondering, I found the service bulliten for the water drainage problem, and have a printout of the fix, the part for it is like $50, but I'll go into it tomorrow if anyone wants.
Old Dec 7, 2004 | 11:14 PM
Ken1997TL's Avatar
Yeah, link/scan that
Old Dec 8, 2004 | 10:31 PM
naba2002's Avatar
major rep points if u can get that print out for the rest of us man , this thin is killin me my car smells like cat piss!
Old Dec 9, 2004 | 03:10 PM
UnsanePyro's Avatar
Registered Driver
Alright, here is a link to the scan. Much thanks goes out to First Acura in Seekonk, MA, and Jason for hooking me up. The pictures are about 1100x1400 right now, so here are the links:
http://img.photobucket.com/albums/v2...Pyro/bull1.jpg
http://img.photobucket.com/albums/v2...Pyro/bull2.jpg
The sealer that you need is something like $50 I was told, because they only sell it in rolls of about a yard. I didn't pick any up, I'm gonna try home depot and see if they have anything similar. If you look by the radiator I believe there is some of this stuff, its sort of like foam, black, and sticks on at least one side.
Old Dec 9, 2004 | 05:28 PM
vanz's Avatar
'97 2.5TL Premium
Nice UnsanePyro. Sometimes I hear water swooshing too, but only when it's raining...Points for you!
Any of you guys take your care into a carwash?
Well a couple of weeks ago, and the only time I took it in to get it wash, there was soapy water coming in from the passenger foot area. Any of you guys experience this? It came from under the glove box.
Old Dec 9, 2004 | 06:41 PM
UnsanePyro's Avatar
Registered Driver
Vanz, I have had that happen one time when it was raining out pretty bad and my car had been sitting for a few hours. I believe its a problem that this TSB should solve.
Old Dec 17, 2004 | 11:18 AM
naba2002's Avatar
i no the part number for the gasket that goes into the tail light....if anyone needs it let me no
Old Sep 26, 2006 | 10:11 PM
toddpa332's Avatar
Did you ever find a way ken how to get the condensation out?
Old Sep 27, 2006 | 12:39 AM
Ken1997TL's Avatar
I used a hairdryer.
The seal fixed it permanently, it hasnt come back.
Old Oct 5, 2006 | 08:50 AM
crucial24's Avatar
those links are dead man
MetalGearTypeS
Aug 29, 2016 08:28 PM
Jboat
Sep 30, 2015 10:58 AM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
hpfiend
Sep 27, 2015 06:59 AM
STL TL-S
Sep 23, 2015 08:52 PM
