Tranny Fluid Drain and Fill
Old 03-25-2013, 11:48 AM
98 3.2 Flamenco Black
Mandy's Avatar
I have been doing drain and fill on my 98 3.2 ever since I acquired it (24K miles then) back in 2000. I have had several drain-fills. Last drain and fill was at 90K. I have been noticing a very slight hesitation on the shifting on the tranny.
This weekend @ 110K and I drained and filled it up again, 3 Qts. There was a good amount oif metal fines on the magnet (prior, it was a slight coating, this time it was oiled up thick). The fluid although not really dirty was not PINKISH anymore.
This is the 1st time I am using DW-1 (replacement for the ATZ).
Lesson learned, while checking the fluid for color and smell, it is really a good practice to replace the fluid every 15K to 20K miles. For the mere cost of 3 quarts of the Honda fluid, you are giving your tranny a better chance of fighting failure due to de-graded tranny fluid.
This morning, I do not know if it is just the figment fo my imagination, but the TL's shifting smoothly.
Drain and fill your tranny fluid every 15K! You will not be sorry.
Old 03-27-2013, 03:39 PM
Khmer Pride
KrayzieDxC's Avatar
thanks for the reminder, got to do mine soon ..and with new breaks pads i got to put in. after this cold weather shift somewhere else.
Old 03-28-2013, 02:56 PM
Mandy's Avatar
I can tell that it is shifting smoother.
Old 04-10-2013, 03:34 PM
KaMLuNg's Avatar
Received 1,090 Likes on 767 Posts
i switched to Amsoil ATF even tho the acura gods always say to use OEM... 170k mi and i haven't had any issues yet (knock on wood)
Old 04-14-2013, 08:47 PM
Mr_Outside's Avatar
Redline makes some really top-notch tranny fluid as well. Thats what I used to fill my TL with.
Old 12-04-2013, 02:32 AM
Radical Member
9632tl's Avatar
I have to chime in and say that my TL has had a barrage of different fluids since I have owned it, and it has 264k on the original trans. I doubt it had been changed more than once before i bought it at 130k, but has seen Honda stuff, cheap atf, and Redline since. Still going strong, although the 1-2 shift is a bit harsh.
Old 12-04-2013, 09:35 PM
main70072's Avatar
^ At 264k miles drop the pan and change the screen.
Old 12-05-2013, 02:32 AM
Radical Member
9632tl's Avatar
I remember doing that at around 150k. You're right, it's probably time again! That and its due for an oil change, and a ball joint.
SidhuSaaB
05-30-2020 12:40 AM
MetalGearTypeS
08-29-2016 08:28 PM
lanechanger
10-13-2015 10:56 AM
xsilverhawkx
10-05-2015 11:00 AM
hpfiend
09-27-2015 06:59 AM
Quick Reply: Tranny Fluid Drain and Fill
