Timing belt
Old Oct 15, 2005 | 07:08 PM
FinedTunedTL's Avatar
Timing belt
can you guys list what parts to buy for a timing belt change?
Old Oct 15, 2005 | 07:14 PM
nick96acuratl's Avatar
um all you need is the timing belt its self unless.. no other parts are required..
Old Oct 15, 2005 | 07:28 PM
you guys do change the water pump, water pump belt, tensioner, and the other belts
Old Oct 15, 2005 | 07:40 PM
spooky3ce's Avatar
Swift 3 B-A-N-G-E-R
But to change the timeing belt itself... all you would need is "the belt"...
but to do the maintenance requirements... yeah... Timeing belt, water pump, thermostat, the three belts, radiator hose(s)...
then you can get into doing a tune up... oil change, spark plugs, spark plug wires, fuel filter, air filter (clean your intake filter)...
Then you can add... tranny fluid change/flush (you can clean the filter in the tranny too)... and radiator/coolant flush... and maybe a new battery (or add the water to the stock one)...
Then if you want to get MORE into it... Change teh gaskets on the engine...
and it keeps going...
i think i'm about 100,000 miles pass due on changeing my timeing belt...
Old Oct 15, 2005 | 07:47 PM
longeye23s's Avatar
i know i need a timing belt change my self, any way since i'm doing a turbo i think i wait till then.
vaughanml2
Nov 1, 2021 10:16 AM
BlkTxAcuraTypeS
Oct 18, 2015 08:05 PM
mossman77
1/2G MDX (2001-2013)
18
Sep 16, 2015 12:21 PM
merc009
Sep 14, 2015 06:43 PM
asahrts
Sep 4, 2015 05:55 PM
