Tcs
Old Apr 24, 2005 | 04:08 PM
veo's Avatar
veo
Tcs
TCS light stays on. does that mean it's working or off?
Old Apr 24, 2005 | 06:29 PM
Ken1997TL's Avatar
That means its off.
Does hitting the TCS switch affect anything?
Old Apr 24, 2005 | 07:27 PM
veo's Avatar
veo
no, i tried pressing the TCS switch and nothing happens
Old Apr 24, 2005 | 11:51 PM
Ken1997TL's Avatar
Is your speedometer working properly?
Any other problems?
Could be the vehicle speed sensor.
Old Apr 25, 2005 | 03:39 PM
WolfpackBill's Avatar
TL no more!
I remember you said something about pulling the ABS fuse out. Like I said on the other thread, if you pull the ABS fuse out, the TCS light will definitely come on because it depends on the ABS to control wheel spin.
Old Apr 25, 2005 | 10:25 PM
TL-Ridaz96's Avatar
Yep, TCS uses the same system as the ABS. I remember reading in the manual saying that if your TCS stays on, it's on! not off. When it flashes, they said to turn off your car ignition and turn it back on, and it should reset. Otherwise, you'll need to check with the dealer. But don't quote my word, I read it a while back.
Old Apr 26, 2005 | 09:26 PM
veo's Avatar
veo
yes, i read the same thing in the manuel. so my TCS is always on now and that can't be good for the engine. should i just put the ABS fuse back and deal with the annoying sound of ABS so the TCS will go off?
Old Apr 26, 2005 | 09:57 PM
pimplayahustla's Avatar
7th Gear
Traction Control sucks - I turn it off everytime I get the car started because it robs power!
I would pull the VSA fuse and that should keep it disabled - pointless feature unless you are a bad driver or live in an area with bad winter conditions.
Old Apr 26, 2005 | 10:24 PM
Ken1997TL's Avatar
It doesnt rob power. Its a passive system.
And our cars do not have VSA.
Mine does, but only because I put a lot of work into it.
Old Apr 27, 2005 | 06:43 PM
veo's Avatar
veo
since our cars don't have VSA what else can i pull out to disable TCS?
what is VSA out of curiousity?
Old Apr 27, 2005 | 09:01 PM
m0s3s's Avatar
vehicle stability assist
Old Apr 27, 2005 | 09:48 PM
Ken1997TL's Avatar
VSA is a combination of TCS and a 4 sensor braking system. Basically will brake wheels independently as needed to keep you on your intended course in a skid.
Yikes
May 3, 2021 04:29 PM
Retep Nitciaj
1G RL (1996-2004)
Sep 18, 2015 10:26 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
Allen_442
Sep 8, 2015 06:01 PM
