Synthetic oil?
Synthetic oil?
I regularly change oil myself every 3k with conventional 10W40.
When it comes to synthetic oil, I have no clue. Is it ok to use Synthetic oil in this TL, the original engine had 245k, I put in a used engine now and not really sure how many miles on this one.
I read in different sites that it’s not wise to use synthetic on a high mileage car.
Is it ok to use synthetic oil and what is a good brand?
I don't really care. I change every 2500-3000 miles so I use conventional, My dad uses synthetic. Good brand, I'd say anything from castrol and mobil1.
I never heard of not to use synthetic in high mileage, so I think its just a myth.
it was leaking some oil once from the oil pan / or rare mainseal, so I went with heavier oil to reduce the leak. Eventually it almost went away. Now, once in a while, I see a drop or two on my drive way.
The risk with using synthetic oils on a high mileage car is that the oil will clean up and that is both good and bad. It is good for your engine, but bad if the buildup is what is keeping your oil seals from leaking. If you're confident in the condition of your engine the change to synthetic should be harmless, but you mentioned having a minor leak already, and personally if it were my car I wouldn't make the change since it could make the leak worse.
I use amsoil engine oil for the high performance cars, castrol synthetic for weekend cruiser, and regular pennzoil for the daily drivers.
Someone warned me about using syn. oil on high mileage car.
thnx
Radical Member
I switched from Mobil1 0-30 to Amsoil sso 0-30
My engine makes more noise now. I didn't notice any improvements, and it costs a shit-ton.
I am not impressed so far. No way am I leaving it in for 25,000 miles.
Received 2,329 Likes
0 weight is too thin for our engines, 5 or 10 weight
You're not supposed to use 0w-30 for these engines. look at your owners manual for oil weight requirements. Amsoil 0w-30 is probably so thin that it is making the engine louder. 0w-30 is for use in extremely low temperature digits(something like -32). Drain and refill with Amsoil 5w-30 or 10w-30. I use 5w-30 personally. With use of a Wix filter, you can run 7,500 miles on the oil. I personally use it for 7500 miles then put a new wix filter on, add oil to bring it back up to level, then drive for another 7500 miles. You can only run it for 25k miles or 1 year (whichever cones first), with normal driving, and 15k miles or 1 year (again, whichever comes first), for hard driving, if you're using an Amsoil filter, which they don't make for our application. Are you buying Amsoil online? Its much cheaper at a local distributor.
Radical Member
The 0 only matters at start up. After its "warm" a 30 weight is a 30 weight.
The oil I used previously was the same weight, 0-30, but made by Mobil1.
My friend is an Amsoil dealer, and I got it at hos cost. Actually, I haven't paid for it yet.
I would stay with 5w30. The engine needs proper lubrication especially when cold since oil hasn't warmed up to it's efficient temperature yet.
IBankMouse
06-13-2020 12:53 PM
lanechanger
10-13-2015 10:56 AM
