Subwoofer and amplifier wire routing from trunk...
Old 09-20-2007, 05:10 PM
ImSofaKingWeTaDid's Avatar
I`m planning on installing a subwoofer and amplifier in the trunk area of my 98 Acura 2.5 TL . The only problem is, how to install it neat and clean.
How do I get the main wires of the amp to pass through my trunk area and then through the front area. I know the brake and rear speaker wires go through a opening on the left side of the trunks siding, but i still dont see a way to get any new wires through this opening . Does the back seat has to be removed? If so, does anyone know the steps for removal?
Old 09-20-2007, 06:07 PM
'13 Hyundai Sonata
TLin401's Avatar
There are so many threads on this already. This is a good time to make the search button your new best friend on this site.
Old 09-20-2007, 06:53 PM
Khmer Pride
KrayzieDxC's Avatar
how? easy, remote wire and rca wires run through the sides and through your trunk and hide them under the carpet
backseat doesnt fold.
Old 09-20-2007, 09:17 PM
大日本帝国
Go90go's Avatar
^ He meant to remove them from the car. Anyhow, you can tuck them under the rear seat frame and under the carpet from there to the deck. Our interiors are pretty easy to take apart, and the entire rear bench comes out with 5 bolts.
~Cheers~
Old 09-21-2007, 04:44 PM
Thank you
Got it. I wonder if the rear bench, is the same as the 3.5? I found a thread with the steps for removing a 3.5 Tl, but for a 06`.
Im not certain of the bolts for the 2.5, I see grey bolts, 6 in all. Probably not the one to remove.
I appreciate the quick response, very cool.
Old 09-22-2007, 12:17 AM
deadsetonlivin's Avatar
The backseat comes up just enough to run wires on it just tug it upwards and itll come right up.
SUPRMN84
10-07-2015 09:46 PM
xsilverhawkx
10-05-2015 11:00 AM
kb1rl
09-30-2015 10:17 AM
27trains
4G TL Problems & Fixes
09-30-2015 09:44 AM
4drviper
09-23-2015 09:00 PM
Quick Reply: Subwoofer and amplifier wire routing from trunk...
