Starting problem
Starting problem
My car will start and run fine when the motor is cold. But once it gets to normal operating temp it has no power and if I shut it off it will not start for 30-45 mins.
I did a tune up and seafoam in the gas tank and through a vac line last week. So I wonder if I loosened something up and its clogging the fuel filter or the cat. And I always run 91 in it.
Khmer Pride
the gas pedal is soft or hard? well my gas pedal is soft that means i have to push the dam pedal half way to get full speed.
you can check your throttle body if it dirty or not. if dirty clean it
otherwise just keeping seafoaming everyweek or so. i put one full bottle near empty and it last for a month with a nice acceleration, have you try seafoaming it in the break booster?
you should try replacing your differential oil to makes a good difference
siularbar
1/2G MDX (2001-2013)
09-11-2015 10:40 AM
