Starting problem
Old Aug 26, 2008 | 10:51 AM
maxteca's Avatar
Starting problem
My car will start and run fine when the motor is cold. But once it gets to normal operating temp it has no power and if I shut it off it will not start for 30-45 mins.
Old Aug 26, 2008 | 02:50 PM
KrayzieDxC's Avatar
Khmer Pride
bad charging,sounds like alternator needs to be replace
Old Aug 26, 2008 | 03:43 PM
maxteca's Avatar
By no power I meant the car is slow.
Old Aug 26, 2008 | 05:27 PM
KrayzieDxC's Avatar
Khmer Pride
as in speed?
Old Aug 26, 2008 | 05:55 PM
maxteca's Avatar
as in speed?
Yes. Sorry I should have been more specific in my first post.
Old Aug 26, 2008 | 06:51 PM
KrayzieDxC's Avatar
Khmer Pride
what gas are you using? 87, 89, 93? try replacing your fuel filter , add seafoam in your gas tank. or just get a tune up.
Old Aug 26, 2008 | 07:35 PM
maxteca's Avatar
I did a tune up and seafoam in the gas tank and through a vac line last week. So I wonder if I loosened something up and its clogging the fuel filter or the cat. And I always run 91 in it.
Old Aug 26, 2008 | 07:58 PM
KrayzieDxC's Avatar
Khmer Pride
the gas pedal is soft or hard? well my gas pedal is soft that means i have to push the dam pedal half way to get full speed.
you can check your throttle body if it dirty or not. if dirty clean it
otherwise just keeping seafoaming everyweek or so. i put one full bottle near empty and it last for a month with a nice acceleration, have you try seafoaming it in the break booster?
you should try replacing your differential oil to makes a good difference
Old Aug 26, 2008 | 08:51 PM
maxteca's Avatar
The gas pedal is hard. I put a full can of seafoam in the gas tank and a half of a can in the break booster when I did the tune up..
Old Aug 26, 2008 | 09:22 PM
KrayzieDxC's Avatar
Khmer Pride
i have no idea, sound like to much of seafoam ,lol
fuel injectors?
Old Aug 27, 2008 | 12:58 PM
maxteca's Avatar
I just noticed that there is black liquid coming out of the tail pipe.
Old Aug 27, 2008 | 01:29 PM
meazz1's Avatar
probably carbon from the seafoam treatment.
I would clean the EGR passage once again.
Old Aug 27, 2008 | 03:52 PM
maxteca's Avatar
I was thinking it was carbon.
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
obert
Dec 14, 2015 11:36 PM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
jordanboi
Sep 5, 2015 01:33 AM
NSolace
Sep 3, 2015 08:02 PM
