Squeeky shock?
Ex-Mod
Squeeky shock?
Great. When I hit bumps, turn hard, or brake hard, my front drivers side tire squeeks. Think I blew a shock or maybe I have a bad spring? Any clues guys?
i have this problem too. for me, the problem came because the mechanic that was reinstalling my suspension forgot to grease the lower bushings. so that mofo squeeks all the time. the only solution that i've come up with is to spray it with wd40 and put some grease on it. but that only remedies it for a couple of days, then it comes back. i've been too lazy to get it fixed cause you need to take off the whole suspension to fix it. the bushing should be this lil rubber round thing connected to the bottom of your spring/shock. check it out. if you're not sure, just wd40 all the rubber bushings.
IIDXholic
3G RLX (2013+)
23
10-19-2015 09:40 PM
4drviper
09-23-2015 07:42 PM
