spark plug install?
Old Feb 11, 2006 | 10:05 PM
noRe456's Avatar
spark plug install?
Hey whatsup.. I just purchased new spark plugs and want to install them. On the 3.2'z where are the spark plugs located? (sorry if this is a dumb question!!) Under the engine cover and how do i install them? just unscrew the old ones and screw in the new ones? Thanks alot!!
Old Feb 12, 2006 | 12:25 AM
BASISON's Avatar
Just take off the engine cover and then you should see the wires that go into the plugs. Just pull 1 wire off, unscrew the old plug, screw the new one in, and replace the wire. Don't try to take all the wires off first, then change all the plugs. Otherwise, you might plug the wrong wire in the wrong plug.
Another tip is to put some anti-seize on the threads of your spark plugs and some di-electric grease on the boot of the wire. This will ensure you don't get any moisture in your plugs and you get a good connection.
Old Feb 12, 2006 | 08:38 AM
esco786's Avatar
also make sure u use a torque wrench to have the pressure perfectly assigned..very easy to install, but a bad install would be very harmful. our cars have 5 plugs on the 2.5 and i think there may be 6 on the 3.2. NGK are usually good but I have much better return from platinums
Old Feb 12, 2006 | 09:04 AM
WolfpackBill's Avatar
TL no more!
The 3.2 engines are distributorless so there're no plug wires to replace. First, unscrew the top engine cover. There are 4 screws. Then you will see there are 6 black little boxes. That's the coils. Unplug then unscrew. Pull them out. then unscrew the plug, put some anti-sieze around the thread and screw the plugs back in. I think they are torqued at around 13 ft lbs.
NOTE: Do this one at a time. DO NOT take all the coils off at the same time. Well, that's about it. Have fun!!!
Old Feb 12, 2006 | 01:27 PM
noRe456's Avatar
thanks guys for all the info.... too bad there's 19 inches of snow here in NYC so i cant do it today.... but thanks for the replies.... if anyone else has any input on it.. please feel free to throw in your
Old Feb 12, 2006 | 01:50 PM
KaMLuNg's Avatar
he got everything i was gonna say...
cycdaniel
Dec 17, 2019 10:58 AM
pstomps
Feb 20, 2017 03:29 AM
Laoch
1G RL (1996-2004)
Oct 2, 2015 03:27 PM
BigJilm
Sep 21, 2015 08:32 PM
NSolace
Sep 3, 2015 08:14 PM
