security system - 98 3.2TL
Old Apr 7, 2003 | 01:40 PM
aarny11's Avatar
9th Gear
I have a standard acura security system with the remote. Recently, i can lock all the doors with the remote but i can not unlock doors which i have to do manually. I changed the remote cells, checked the fuse everything is fine. I am almost thinking of replacing the security system( any suggestions) because i need one with this car.....Thanks in advance..
Old Apr 8, 2003 | 07:38 AM
FSUPaintball's Avatar
7th Gear
I had that same problem -- but it ended up being just a broken key fob. If you have another remote lying around, try it.
Old Apr 8, 2003 | 11:12 AM
aarny11's Avatar
9th Gear
Don't have Remote
FSUPaintball ,
Thanks for the reply. I don't have another remote. Can i get one from the dealer?
Old Apr 8, 2003 | 11:30 AM
7th Gear
Dealers will charge you an arm and a leg (most of the time they want over $60 for a remote ... and they may even charge you to program it).
I got a few off of Ebay reall cheap --- $10 or 15 a piece. They are also VERY easy to program yourself.... so, just search around on Ebay for one.
Old Apr 9, 2003 | 03:50 AM
YNOTxTONY's Avatar
Try http://cgi.ebay.com/ebaymotors/ws/eB...&category=6763
I got one a couple of years ago.
Old Apr 11, 2003 | 09:01 PM
KaMLuNg's Avatar
hold on.. don't order just let.. i will check my garage later tomm... see if i have mine left over... i put an aftermarket alarm in so i don't need it nemore... ill let u know..
Old Apr 12, 2003 | 05:36 PM
praxiis's Avatar
Similar thing happened to my car in the fall - except mine wouldn't lock. I took apart the remote, and it didn't seem to be the problem. Before this happened, my alarm would ocasionally go off without any provocation, but not since the lock button didn't work. Now, the locking started working perfectly fine, but my alarm's been going off again. I'm taking it in to get serviced on Monday, and I'll let you know what they say.
Craig
Old Jul 21, 2012 | 02:35 PM
Princess Erin Elizabeth's Avatar
5th Gear
help with security system
my 97 tl was broken into by way of the driver window. now i cannot use my key to unlock nor will the locks unlock. once unlocked they immedielty go back to the lock position. Also my driver door handle will not open? and suggestions or help. please
Old Jul 21, 2012 | 06:21 PM
main70072's Avatar
That driver's door handle may have something to do with what you are experiencing. Try fixing that first and see what happens.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
tsx_boy
Dec 13, 2019 08:33 PM
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
