Removing gold accent stripes
http://img.photobucket.com/albums/v4...8/06220011.jpg
http://img.photobucket.com/albums/v4...8/06220009.jpg
its kind of hard to see but theres a gold stripe going down the car, im sure you all know what im talking about, but i hate it. i dont like the gold look with the black and chrome, i spray painted all the badges black and wanna get rid of this stripe now.
on some sections i pulled it completly off like a sticker without any problems but other parts it seems like only half of it came off.
im wondering if anyone has any ideas for how to get whats left off. i can get a pic if that would help...
3M make an trim/adhesive remover that will take that stuff off with ease... You would have to be careful as to not leave the product on your paint too long... might hurt it... Should be able to pick this stuff up at any parts store... Unfortunately expect to shell out about 6 bucks for a can.
100 POSTS!!!!
100 POSTS!!!!
i tried taking them off like you would a sticker, and on some sections only half of it came off. and i cant get my fingernail under whats left and im afraid to use anything like a razorblade.i need something to loosen the glue under whats left or to get it some of it off so i can peel it like before, then ill worry about removing the remaining adhesive
Registered Driver
The pinstripes come stock with 2 layers. One is the gold, and then under that there is a silver layer, it is possible to pull them apart, leaving one on the car.
You can see that part has been removed, the rest that you see though was actually paint (the top line) and lack of paint (the second line) iirc.
Beware though, I don't know why, but not all of my pinstriping was painted underneith. I ended up having to re-stripe it, which was a bit of a pain, I went with black though.
Some sort of adhesive remover like goof off will help in removing things, but all I used was a heat gun. Warm up a section and pull slow, once you have the hang of it, you can peel an entire door without it ripping. Good luck.
2003 Acura MDX
what kind of rims are those?
there from the second gen tl, i didnt put them on there the guy before me did.
and someone i know is bringin over something that his shop uses so hopefully that'll work, but thanks alot for the help.
2003 Acura MDX
I like that, i wonder how much a set of those rims with tires would cost me..
i found out that there was body damage to the car in the sections where it came off clean, because obviously they repainted those sections and went over the whole car with a sticker style stripe, and that would explain the overspray around the trunk and spoiler.
