rear speakers
rear speakers
on 96 2.5 TL.
how do you remove the rear speakers? and the speaker grills?
i heard you need to remove the rear seats then remove the carpeting to reach the speakers.
![Talking](https://acurazine.com/forums/images/icons/icon10.gif)
pretty quick:
1. open and empty out the trunk.
2. climb in trunk and look straight up at the speaker from below.
3. you will see the speaker, four bolts and fasteners.
4. loosen nuts and lift the grill from inside the car.
5. re-attaching the grill is quite tedious. you must thread the four bolts through the cardboard and then the holes, quite a pain in the @$$.
6. once in, tighten up and you are done....
hope this helps =P
hope this helps =P
the thing is though, there are those little plastics clips under the lining inside the trunk. then there are the screws, but they screw DOWN INTO THE TRUNK. so i can't unscrew them. anything else i can do? thanks for the input.
whoXwanXsum
all i did was lay in the trunk take out the 4 screws holding the cover dwn, then unbolt the speakers from inside of the car. it was very ez but i have a 3.2 but i dnt think that should matter. i kno one thing u gonna laugh ur ass off when u see the stock speaker!!! sum cheezy **** 4 such a nice car.
i have a 2.5...
no i tried again, this morning but i just can't figure it out! damn.
there are these four screws that are screwed DOWN (into the trunk, can't unscrew). there are also these little plastic clips. now some of them are yellowish color and they are pretty small (about 4 or 5). and then there are these big gray ones (about 4 i think). i can unclip the small yellow ones by using pliers. then i tried pushing up the carpeting from the trunk. that didn't work.
long story short, it didn't work again. i'll probably go ask the dealer sometime.
btw, anyone know how to remove the rear seats on 2.5? see if that works. the guy at tweeter said thats what you do.
o and also. i just got my alpine 7873 deck last night. gonna install it on saturday.
akbears15
15
11-05-2015 07:06 AM
Pegon95
09-15-2015 01:54 PM
